High output alternator??? Anyone found one or put one in yet? mechman doesnt have one on their web site yet. :(
2019 Denali 1500
Ok. Discovered that the 2018 alternator should be the same. Since ordered a 370 amp alternator and a Big 3 upgrade. Will install and let everyone know how it works.
  • 8 months later...
So what was the out come from this? Did the alt from the 2018s work with no issues?
I never installed it. Still have it in a box and contemplating still doing the install. You done it yet?
Nope I have not. I was hoping you had gotten around to it so I would know if this was a possible solution. I'm trying to find a way to get more power as well, gonna need it to feed the audio system I plan to install
Just wondering if anyone has installed a mechman 370 amp alternator onto a 2020 gmc sierra 6.2L engine yet??
My motor does not have a belt tensioner and has what mechman calls a “stretch belt”
says it cant be done unless i just install a 250a alternator and that isnt big enough for my audio needs.
The OEM stretch belt will work on the 370. I havent installed myself but measured a new OEM belt and sent the specs over to mechman and they say it will be fine. The OEM pulley is 55mm and the mechman is 46mm.
This info came from Richard at Mechman.
The bigger problem thay I see is the 200a fuse block that is built into the battery terminal. It should be as simple as disconnecting that and then running a new HOT wires from the alt to the battery terminal with a 400a fuse in between.
I dont know enough about alternators and the GM computer to know if thay will cause other issues or not.
Any ideas???
Any ideas???
I dunno but I guess I’m going to tackle it no matter what. Already spent around $7,000 On this Sundown Audio system and I’ll be damned if I’m going to let a damn alternator stop me from having a bitchin stereo in my new truck.
This is what my battery looks like. It’s about to go bye bye as I have two Limitless Lithium  45AH lithium batteries to use (90AH combined) total weight 36lbs and has the power of 18 AGM 50lb batteries :)
The Police Package Tahoe gets a 170 Amp high output alternator and 720 cold-cranking amps primary battery and 730 cold-cranking amps auxiliary battery (dedicated to emergency equipment) With all the gear that a police vehicle has to power, they have this pretty well covered, you might consider going that route?
    RichardRS
    RichardRS
  • Who's Online   4 Members, 0 Anonymous, 806 Guests (See full list)
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
