The Police Package Tahoe gets a 170 Amp high output alternator and 720 cold-cranking amps primary battery and 730 cold-cranking amps auxiliary battery (dedicated to emergency equipment) With all the gear that a police vehicle has to power, they have this pretty well covered, you might consider going that route?
Thats the tahoe. We are talking about the 1500 trucks. Tahoes engine bay is going to be different than the 150p trucks im sure. The problem with our trucks is that there is zero space for a second batter under the hood. Im putting one in the back of my bed behind the cab on the right side underneath my bed cover.
I have the 170 alternator in my RST and asked my dealer SM if I could just install the factory 220 without any problems, like an ECU change. He did not know and said he would find out. These new trucks have something called a smart charging system so it makes me think the alternator may be controlled by the ECU. Any thoughts? I want an upgrade to power some communication equipment.
The built in fuse on top of the battery is only 200amp. I would only assume you would need to replace that assembly which is 900 bucks with the one for the higher amp alternator which comes on the snow plow package.
I know this may be obvious but have you visited your local Car Audio shop? There stands a good chance they have installed a high end audio system in a similar truck and may have some solutions. Back in the late 80's and 90's (my SPL days, we typically used an ambulance alternator, extra batteries and stiffening capacitors to provide extra juice. One of my bigger builds was a 1990 Geo Storm. It had (8) Kicker 12's powered by HiFonics series VIII amplifiers. Mids/highs were made by Savard (their Rap series).  I was knocking cans off grocery store shelves when cruising parking lots. Ok...enough reminiscing.   :)
I know this may be obvious but have you visited your local Car Audio shop? There stands a good chance they have installed a high end audio system in a similar truck and may have some solutions. Back in the late 80's and 90's (my SPL days, we typically used an ambulance alternator, extra batteries and stiffening capacitors to provide extra juice. One of my bigger builds was a 1990 Geo Storm. It had (8) Kicker 12's powered by HiFonics series VIII amplifiers. Mids/highs were made by Savard (their Rap series).  I was knocking cans off grocery store shelves when cruising parking lots. Ok...enough reminiscing.   [emoji4]
I've got 2000 watts using my oem 170amp alt and its fine. I have the denali so its LeD all the way around and I haven't had a need to add my bigger alt or a second battery however I'm not adding more accessories so getting this resolved sooner is my next priority.
This is the reason for my upgrade.. Sundown Audio SALT-6  6,000 watts RMS and 10,500 watts at 1 ohm mono..
its a power hungry sumbish.. at idle pulls around 150amps and 1000 amps peak. Has 3 1/0awg power wire inputs.
I also have two 45AH lithium batteries from Limitless lithium that have the same capacity of
18 50lb AGM batteries. Really a no brainer as I dont want to be lugging around 800-900 lbs of batteries as these lithiums only weigh like 36 lbs combined. They charge fast as hell too.
Sundown makes great gear. Will you be upgrading your mids/highs?
Nice gear. I have an SD3-10 that will be hooked up soon.  What kind of subs you running with all that power?
For now i will have 4 X8V3’s on the salt -6. I’ll keep this for the first 8 months to a year till I have the box for my 4 sundown 12ZV5’s and I’ll have to buy another sundown salt-6 to get the max spl out of these subs.
Yes I plan on using Focal K2 mids and tweeters and still undecided on the amp for my midrange and tweeters.
The Focals are a nice choice for mids/highs.  I had Hertz Mille Pro's in my last truck and was impressed with them. For the mids/highs amp, since I'm still old school I went a Class AB American Bass VFL 350.4. (175 x 4 or 500 x 2 Bridged at 4 ohms).  There are however lots of choices in Class D that will work as well.
3 hours ago, Paul 2020RST said:
Sundown also has their new full bridge line of amps.  I know there is a 4 channel in the group.
For the 4 -12’s, I’m assuming you are removing the back seat?
No the back seat will be staying and i’ll be cutting a port hole into the cab.
probably like 12” tall and 30” wide or so.
Nice you will definitely be loud I’m also cutting the cab but I’m doing 2 JL Audio 13w7 4th order, hole will be 10x10 so not too bad
Any updates on the high amperage alternator install?
I called Mechman 6-8 weeks ago, and as of now they have not resolved the smart charging issue on these trucks.  There has to be a way to install a big alternator.  Said they are working on it.
As of right now I am running Focal components in the front and Focal coaxials in the rear with two Focal flax 12's.  One Audio Control D4.800 and LC800.1.  Mids/highs amp is only using around 400 watts and the sub amp is putting out a little more than 800 watts.  So a little over 1200 watts at full tilt and voltage never moves from 13.9 at both amps.  I have an oldschool Cadence A7HC that makes really good power for a 20 year old amp.  I built an enclosure for two Sundown ZV5s for a guy recently, and tested it in briefly in my AT4.  Voltage was 13.8-13.9 at full tilt.  I did not clamp to see how much power it was putting out but I installed it in the other truck on a Salt4K, the Salt amp was definitely louder, but my old amp really surprised me.  This being said, I feel like we have pretty good stock electrical in these trucks.
If the 220 amp alternator would interchange, I think it could handle 3000 watts if a powerful AGM or Lithium was added.  I'm not saying the stock will handle the Salt6K by any means.  370-390 amp will definitely be needed for all of that gear.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 395 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
