I just installed mine yesterday. I wired my positive wire to the 1st position on the wire block as shown in the photo posted above, factory has it marked as "post 1". All off the posts are HOT all the time. Even when the truck is turned off. When doing this the switch provided by RC has a green light that lights up when you turn the lights on. The bad thing is a red light lights up when the switch is off. The red light stays on even when the ignition is off. Thankfully I did not pull the wires through the fire wall yet. So I am going to rethink how I need to wire these up.
I want to run a wireless relay and use button 3 on my home link system to activate the lights. But I am not sure which wireless system to buy?
On 11/25/2019 at 4:42 PM, slj2008 said:
HAS any one installed a led light bar behind the grill of a 2018 with shutters ??? If so ANY information will be helpful . thanks
I have a post on here where the baja designs bar that says work with active shutters did not fit behind my grill of my LTZ.
2 hours ago, Mike Emerson said:
I have this wireless controller coming in from Amazon https://www.amazon.com/gp/product/B01DOUV83K/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
I completely forgot about the home link buttons up there.  I will hopefully be installing by next Tuesday and will let you know if it works with this kit.  Thanks for that idea!
Please update this when you get it going. I want to know how to run this with the RC kit? Do I still need to run the RC module inline with the module from this kit?
Got to work on the truck early and got the lights installed yesterday.  The wireless kit came in today so I had a couple minutes to mess with it.  The home link buttons do work for the receiver but I had to program one button for on and a second for off.  I used all of the RC wiring harness and just unplugged the switch and plugged in the wireless receiver there.  Will look closer at it this weekend but it all seems to work great.
If you find a controller that has one button for on and the same button it off it will work with 1 homelink button.  I used this one which is a 2 channel and used the other 2 buttons I had for both channels.  Mash it once comes on and again and goes off. https://www.amazon.com/gp/product/B0068D0OBI/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
Nice, I had already bought the one I have before I heard about the homelink button idea.  I don't have a garage and never even paid any attention to them.  I would have been happy just to have the remote and not have to mess with running a wire through the firewall.  It is nice to have the buttons work also though and not have to dig the remote out of the console.
Got a question for those that installed the lights already.  Looking at the instructions when I cut the inserts out of the grill, what holds the light in place and keeps it from falling through the grill on the bowtie side of the lights?  I see the outside part with RC on it will be held by the remaining grill but looks like the other part will just fall through on my LTZ or am I missing something?
The brackets hold it on from the back and essentially clamp the light in place.
I checked them last week and they have not moved since I have installed them.
So the side towards the bowtie does not fall through?
On 10/21/2019 at 5:33 PM, TXGREEK said:
Oops, sorry
Sent from Above
Try GM 84469521
Nope.
It holds in there pretty good.
Edited by Smoothbassman
There are 2 little brackets that go on both sides of the 2 lights. These adjust the angle up and down that the light points in. Then there are 2 more brackets per light that hold it to the back side of the grille. 1 for each side. 1 of the four brackets goes in a specific location. Once you bolt these brackets in the lights are locked in place. But you can not adjust the aim of the lights without taking these brackets off.
The RC direction's are not the best.
In my experience, past and present, drilling new holes on any of the brackets is an “individually” optional. In my case, I drilled new holes and used stainless steel screws, washers and nuts to help lessen the possibility of any future rust.
Sent from Above
  • txab changed the title to Rough Country LED Grille kit 2019+
Well I got it in over the weekend.  I will start a new post on the whole process but they apparently did not test the kit on a LTZ or a High Country.  The grills are different.  It fit but the off bracket that the instructions say is for the pass side with the dip in it needed one more bracket like that cause the LTZ and the High Country grills have the same dip on the drivers side also.  I will test it out some more at night but so far I am not impressed with the amount of light it puts out.  I was hoping to get more light above the headlight stopping point but although it does have light it just not bright enough for me.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
