I chose to not go with the grille kit, I did not want to cut up the stock grille. I ordered the 20” rough country light bar and was very happy with the quality for $150. Installed it behind the grill and love the outcome.
What bracket did you use for this install. Looks good.
Sent from my SM-N960U1 using Tapatalk
On 10/8/2019 at 9:33 AM, CMillSilverado said:
...Baja D was willing to sell me just the mounts. I'll post up a review when I get them mounted up tomorrow.
https://www.bajadesigns.com/Products/Chevy-Silverado-2019-Fog-Pocket-Mount-Kits.asp
I've had thoughts of trying to design a mount just about like those to 3d print.  Temp might be an issue though.  Was thinking I'd wire up a relay off of the high beams so I wouldn't have to worry about adding an extra switch...
Mine run off the factory fog light wires with no issue and come on when the high beams are on with a jumper wire.
Well
I got mine installed. They look like they are from the factory the. Way they fit.
Took about 2 hours to knock out. It's crazy how simple it is to get the grill off of this truck. 10 push clips, 4 bolts, and it pops right off.
Need to wait until tonight to see how much light they put out. 90137b6277bf66e31071fbb168b460a4.jpg1caf9ff103faaf76df49e29a44472da7.jpg
  • Like 4
Alright, I know everyone wants to know what these lights put out.
Here is a photo of just the LEDs running with no other lights on.
You can see that the lights produce a flood pattern that fills in nicely. The spread is much taller than I expected.
There isn't much throw on these lights so don't get them for that.
They are stronger than the low beams but don't reach out far enough for high beam replacements.
I would have loved if this light was a combo pattern. Floods on the edges and throws down the middle.
  • Thanks 1
Ooooh. Kinda what I’m looking for.
Picture with the lows on also?
Ok. Here are a couple of shots at an intersection
Lows Only
Lows and LEDs
  • Like 4
  • Thanks 1
Lows Only
Lows and LEDs
Thanks for the pics. I hate to ask but any comparison to stock hi beam output as well?  That’s the big one for me.
Already ahead of you.
Another set of shots.
Lows only
High Beam Only
Lows and LEDs
High Beams and LEDs
  • Like 3
In general. These lights are an excellent choice for fill light. Hits the edges really nice. You don't get a lot of throw with these to replace high beams, but you can see a bit further than the low beams only.
I would say these lights are kinda like a mid throw fill light.
Works well in findings critters that are trying to become hood ornaments at night.
Caught this guy coming up out of the ditch as I turned the corner. Took his sweet time getting across the road.
Lows only
High Beam Only
Lows and LEDs
High Beams and LEDs
Awesome information.  Thanks for taking the time to post these.  Truly appreciated!
  • Like 3
Great pictures, how hard is it to wire up?
Also is it hard to cut out the grille?
Grill took me an hour to remove, get it taped up and cut out using a mini hacksaw and get the lights installed in the grill.
15 minutes to get the relay mounted to the firewall, and route and zip tie all of the cableling up so it looked nice and neat.
5 minutes to reinstall the grill
The hardest part of this job is getting the wiring thru the firewall. I used the plug in front of the door jam on the passenger side using a fish tape to thread it thru. Took me an hour to do that, then route the control switch over to the spot that I wanted it. I couldn't reach the firewall plug behind the battery without removing it. I wasn't in the mood to remove all of that stuff to get to it.
I had a wireless lighting controller as a backup just in case. Didn't need it after all and sent it back to Amazon.
One more question, in your pictures, are the fog lights off when you put the high beams on? Did you mod it so that the fog lights are always on?
Modded.
My fog lights are on automatically with the high beams.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
