Odd sound while in 4WD and coming to a stop or turning
Hey all,
So we got the first big snow in our area tonight so I kicked in the 4 wheel high and noticed some odd sounds coming from the truck.
NOTE: This does not happen in 2WD.
It's a bit hard to explain, sounds like a mechanical-almost grinding type of sound. It's really present whenever coming to a slow or stop and it sounds like a grind then coming to a stop it sounds like something from the front like a space ship winding down lol. It's all coming from the front.
When turning slowly, it also makes a pretty horrid noise, kind of squeaky grinding as well. No real mods yet, waiting for better weather but anyone experience something similar?
Turning can produce some odd noises/movement when 4 wheel drive is selected because one tire has to travel further (move faster) than the other to go around a corner.  Going slow I have no answer but the dealer might.
You're describing normal 4WD activity to me. If you use it when you don't really need it, you will get weird sounds. Like on dry dirt.
I know you said you had snow, how much? Like a lot? Or was it a 50/50 mix of snow covered road and clean spots cleared by the snow plows? In my experience with 4WD, if you aren't continually driving on actual snow (your tires never touch pavement) then you will get noise from 4WD.
This!  ^^^  Oh, make sure your front axle has fluid in it!
Agree with the others.
I stick with “auto 4x4” unless we are talking a foot of unplowed snow. Really, auto does nearly as well as 4 high in the snow (albeit with a slight delay before engagement during slippage), and leaves no chance of binding. It’s my go-to mode from November through March...
Is this your first 4WD truck? I agree that it sounds normal and you likely were transitioning between slippery and less slippery pavement. If you can see the pavement, 4 auto or 2HI would probably suffice. You only need 4HI if driving on unplowed roads. And remember 4HI does not improve handling, steering or braking. It only helps you accelerate faster. No need to out-drive conditions if the roads are actually bad.
Thanks for all the replies!
My father who has driven 4x4 trucks his whole life was riding with me and said it sounds like the front half of your truck is falling off lol. It's extremely audible, I have had 3 other 4WD vehicles prior to this, 2 of which were trucks and dont get me wrong, I understand the sounds from a 4WD truck but this is like a mechanical grinding coming to a sort of clunk when coming to a dead stop on a straight line with no turning. We had about 5 inches of snow hit within an hour after rain so it was pretty bad conditions.
  • 1 month later...
This truck is my first 4WD/4x4, and I noticed something similar.  So a few weeks ago, I put my truck in 4HI, to drive in the snow, no issues.  Put it back into 2WD, when I got home, and haven't needed it since, until this afternoon.  When I put it in 4HI, it was grind/vibration central, but when I put it back in 4AUTO or 2WD, there is no issues
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
