Winter Tire Report
I just installed dedicated winter tires today. I was going to wait for more drive time before reporting but since I was able to immediately compare to stock tires with the weather we just received I decided to mention it right away. Also in case anyone was considering them the time to buy them is just beginning. In a word, incredible. Where the stock tires instantly road on top of the deep slush these cut right through maintaining contact with the road. Traction on the hard pack was night and day different. I can’t wait to use them in all kinds of winter conditions. Also they drive better on pavement than the oem tires that came with my truck. Bridgestone Blizzak DM-V2. 2019 Silverado. I wish I hadn’t waited so many years before trying.
This year im going to use up my stock duratracs. Next year ill put dedicated winters on my 18" rims and buy 20's for the summer.
You definitely made the right choice.  The Blizzak is an awesome tire.  Also reduces mileage on your summer or all season tires.  I went with the BF Goodrich Winter T/A KSI.  Really nice tire, not loud and noises at all,  and really bites in the snow and slush.
I kinda wish the lady that T-boned my work van this morning on 35E had snow tires lol, maybe she wouldn't have lost it and darted across 3 lanes. Good thing it was a rental.
I always tell people, snow tires should seriously be considered if you drive a lot in the winter.
My GMC Sierra has the X31 with the 20” wheels and 275/60R20 tire.  I’m also looking at the Blizzaks DM-V2s but was going to put them on 17” wheels because it’s way less expensive.  That said these tires are 265/70R17 and if I compare the tire sizes, the winters would be 4.2% smaller which is outside the 3% rule.  That said this tire size is also listed on the GMC website.  I’m assuming I’m safe with the smaller tire size listed, any advice?
Thinking going narrower would also be helpful in the winter.
The tires on the base model trucks are 255’s and 17” rims so thinking I’m safe to run that size on my 2019 Sierra Elevation that normally run 275/65R20’s(normal size is 275/60R20 but I bought the truck with upgraded and slightly larger tires.)
Any issues besides the speedometer being out a little running smaller diameter and narrower wheels and tires in the winter?
    CaptainDad
    CaptainDad
  • Who's Online   7 Members, 0 Anonymous, 566 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
