3 minutes ago, SILVER SLED said:
It will only smoke that truck if your both racing at part throttle.  I’ve personally never tried that.  It doesn’t add any wot horsepower, it just tricks you into thinking you have more.
Not through the quarter. It responds and takes off soo much faster the other one doesn't have time to catch up.
My understanding is it tricks the truck into removing torque management.  ie, instead of the throttle blade "slowly" opening, it's instant (or somewhere in between instant and stock).  It's meant to put less shock on the drivetrain for reliability
@GTPprixcare to weigh in on yours vs theirs?
I too worry about warranty.  Are you able to get around the speed limiter (and other things this other device can do) through the BCM alone?
How is instantly adding hp less of a shock than slowly adding hp?
  • Haha 1
Um... tap your thumb with a hammer
Now tap it harder
Now go to town
Which hurts more?
To be closer to apples and apples, neutral drop your truck several times and let us know how that trans (or at least the input shaft) holds up
Google "Torque Management", I didn't just come up with this out of thin air
Edited by Rob Mugs
[mention=130449]GTPprix[/mention]care to weigh in on yours vs theirs?
Not sure what you’re after specifically however you can find the features list on the site which is pretty extensive. Warranty wise our biggest customers are dealers if that tells you anything ;)
https://www.whiteautoandmedia.com/product/t1-pickup-wams-spec-bcm-programming/
  • Thanks 1
3 minutes ago, GTPprix said:
Not sure what you’re after specifically however you can find the features list on the site which is pretty extensive. Warranty wise our biggest customers are dealers if that tells you anything ?
I just noted the price of yours was less and has more options.  To be honest, I'm not a fan of the piggy back systems but they DO seem to be better for those uptight dealerships
Guess the only thing I wasn't 100% sure on was that speed limiter.  Would have thought it was part of the ECM
Edited by Rob Mugs
It's not adding HP it's opening the throttle faster. Therefore the truck takes off faster. faster throttle = faster take off. It's a huge gain but it will break stuff.
What he said :)
Now tap it harder
Now go to town
Which hurts more?
Sorry, the post I quoted you sounded like you were saying that instant torque/hp is easier on the drivetrain than slowly adding it.
I’d say dealer wise you’re fine with either. BCM’s don’t report CVN’s like an ecm or tcm so unless you tell them they really aren’t going to know and the odds are pretty good they are one of our customers anyhow ;)
BCM is actually the speed limiter master, that’s why when you get tunes they have to set it from “external” or “other module” to internal.
  • Thanks 1
It 100% is
Lift your rear end up 1/2" off the ground and spin the wheels to 100mph in the air.  Drop it down and watch everything shatter.  This is the extreme but torque management hinders performance for durability
11 minutes ago, GTPprix said:
I’d say dealer wise you’re fine with either. BCM’s don’t report CVN’s like an ecm or tcm so unless you tell them they really aren’t going to know and the odds are pretty good they are one of our customers anyhow ?
Thanks for the clarification, Chris.  I haven't programmed an ECM myself since the 870/165s in third gen F-Bodies where you still needed to wipe it using UV light lol
Heh the good ol days LOL did my first tuning the same way on the LC2 :)
FWIW, I plan on ordering Chris' option since I first started looking just for having the Window UP via keyfob function.  The fact it comes with oodles more is icing
I'm also a sucker for a small business over large corps ?
Edited by Rob Mugs
    • I only have a few of the ACDelco blue remaining. One or two of the (old, old) ACDelco Professional boxes, and a couple of the newer style GM boxes with the simulcast in Chinese along with English. FWIW they've all been pretty good, regardless of where they are made, and in 20 years I've never had a problem with an e-core filter.   Now I have a couple of the "A" series in my home inventory. They come in a plain white box with the GM hologram sticker and model information. Have not installed one yet, want to use up my oldest inventory first.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
