On 2/20/2020 at 2:21 PM, rblanch said:
Hauled a 40' toy hauler around 17,000# around 1,200 miles over the last week and averaged 8.5 mpg about the same as my 2017 L5P with 6 speed.
Not bad!! What was your average speed?
2020 GMC Sierra AT4 2500 Duramax towing 9k bumper pull travel trailer. I’m seeing about 10 MPG all around, when I haul from sea level to Eastern Sierra Nevadas (8k foot climb) and back. Averaging 65-70 MPH. If I drop down to 55-60 MPH, as the speed limit in CA is 55 MPH when towing, then I see a couple MPG pickup. Towing up and down the coast at mostly sea level, I see more like 14 MPG.
I also didn’t get the truck for MPG, the big difference over my gas truck is a rip right up 6%+ grades at 60 MPH at 2k RPMs with the trans barely heating up. My old truck struggled up grades when towing (35-45 MPH) and I go to the mountains often with the trailer. 8-10x per year. More importantly than going up, I can safely come down with my wife and kids. The old truck concerned me about breaks over heating. Not anymore with the “exhaust break”. That back pressure from the turbo brings this whole setup to a crawl on step inclines. Love the truck. The tech, the power, and control!
This is EXACTLY why I am upgrading to HD Diesel when only pulling a 8k# TT.
  • 7 months later...
Finally purchased my 20' 2500 D-Max High country. First pull 400 miles. 7k TT 11 MPG. Flat land from Houston to Oklahoma. Before I left I noticed my soot level was at 80%. I did not want it to start a regen while towing so I used my banks idash to initiate a moving regen. Love this banks idash!! Funny thing was that once I was towing the EGT stays around 750 deg. And that is high enough to keep the soot level from climbing. At times it would even go down a bit.
Another strange thing is the transmission temp. I am used to a transmission somewhat leveling out when traveling across flat land. However I noticed the temp would climb to around 160 then drop back down to around 145. The surround camera are absolutely amazing!!
Edited by Lfod1836
  • 5 weeks later...
I know 2500 has 11.5" and 3500 has 12" ring pinion gears but they have same gear ratio 3.42.   So  Are they same mpg?
Only pulled my old bumper pull stock trailer a few times, but averaged about 13 according to the display.  That was short distance in tow/haul mode and with some idling to load and drop off.  Have yet to haul the equipment trailer with it.
  • 3 weeks later...
On 12/10/2020 at 1:50 PM, Laidback said:
What mpg are you guys getting without towing a trailer?
Around 17-18 mostly highway with some city mixed in.
I get 8 mpg towing 17,000 # 5th wheel toy hauler . My 2017 got 10 pulling the same trailer. the 10 speed with 3.42 axle ratio comes out of over drive a lot more at 68mph than the 2017 with 6 speed and 3.73 gearing.
  • 3 weeks later...
I am getting around 11 MPG with my RAM 1500 EcoDiesel towing my 7.5k travel trailer. Should I expect the same MPG with AT4 6.6 Duramax or less?
  • 4 months later...
I get 9-11mpg towing a 7,500 TT with a half-ton 6.2 TB towing at 75mph. I just put a deposit down on 2500 Dmax as I feel it's much safer to have a bigger truck at this weight and speed regardless how good the 1/2 ton felt pulling the trailer.
    Greg3160
    Greg3160
  • Who's Online   5 Members, 0 Anonymous, 437 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
