Is the only termination point the wires under the dash or is their a spot under the hood that you can hook up to the switches? Also I only have 4 wires but 5 switches. how do you terminate the fifth switch position?
The only termination point is under the dash. Switch 5 is prewired for a strobe light in the roof, and the other end is in the spoiler. You could pull that wire out of the harness and cut it and then use it for what you want.
Thanks Kevin
  • 5 months later...
So has anyone had dealer install this? What did they charge?
i bet its over $500. the 5th switch is the green wire in the gray plug.
I tried asking a couple of dealers around me and they all turned down the installation. With all the videos on youtube, you can do it yourself very easily. Hardest part is popping off interior panels. Everything else was easy.
  • 6 months later...
Well the first picture is similar to the one in my truck. Just a different color. Well I added a 5 aux switch panel to it today. I didn’t want to cut into my dash just to add some switches. Plus I wanted it to look factory. So since the fold down compartment for the eye glasses isn’t really big enough to hold glasses. I decided to use that space. So I cut out the hole with my router table. Then Cut out couple of abs panels with a rectangle hole in it. big enough to snug the switch panel body into it. And drill a small hole on each corner of the abs panel. This becomes my mounting plate. Then Epoxy one abs panel to the back side of the compartment. And the second one. I epoxy that to the switch panel body. Then screwed ( using the 4 holes i drilled ) the switch panel to the abs panel on the back side of the compartment. It turned out amazing. What do you all think of it.
So my gmc truck is 2017 2500hd Denali. And this kit is made for newer trucks.
So I have to extend all the wires, and hardwire it in. ( gotta find abs locate couple of wires on the truck to tap into to make the switches work with the leds ).  Since I don’t have the factory plug that this kit comes with. Plus I have to find a place to mount the fuse / relay box.
On 4/8/2020 at 6:32 PM, mkeddie said:
Thanks
I won't need the knee bolster as I'm gonna extend the wires and put the switches up in the headliner
Sent from my Moto Z (2) using Tapatalk
So I have to extend all the wires, and hardwire it in. ( gotta find abs locate couple of wires on the truck to tap into to make the switches work with the leds ).  Since I don’t have the factory plug that this kit comes with. Plus I have to find a place to mount the fuse / relay box. 05FD42DF-4B82-46F2-A0C8-0C1197D811AF.thumb.jpeg.6b4875d8f4a9621e26108b3fd2e750ae.jpeg
@Robo9831 You did a very clean job on cutting out, and installing the switch stack.  I like where you have this installed for a couple of reasons:
* Easy to see which switches are activated
* Easy to manipulate the switch while keeping your averted vision on the road ahead.
I was not excited to see the OEM location, so this is a nice alternative.
Will look forward to see how you end up making all your connections.
Nice work! :thumbs:
Nice work! :thumbs:
Thank you.
    DaleB
    DaleB
  • Who's Online   5 Members, 1 Anonymous, 1,522 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
