Exhaust
Spencer Burns
Has anyone just changed out the stock muffler and removed the resonator on a ‘17 Silverado with the 6.2? Leaving the stock piping and all. If so, what muffler did you use
I went with a cat back but for the price I would recommend Carven. Great quality, American made and it sounds amazing. I went with the Competitor, it's aggressive, but not bad when cruising.
Sent from my SM-N975U using Tapatalk
I have a magnaflow 12909 muffler with the butterfly valve cut out and the rear resonator removed.  It's just deeper than the stock muffler and slightly louder.  I choose it because I ran it on my older 6.2 with headers and not cats and resonator removed and I loved it.  It's to quiet with stock exhaust manifolds and cats.  It's louder but not enough.
It will be perfect once I get the headers on here soon.
I was thinking of doing the borla xr1. Forgot the part number but it’s a 3.5 in/out. Then said screw it and did a muffler delete to hold me over.
Still trying to figure out what to do. No one around me works with 3.5”. They have the pipe and will weld in straight pieces but no one has the die to bend. Debating on just doing a corsa since it’s full 3.5”. Will see
I’ve never seen an exhaust like this. Out of the cat 3.5”, necked down to 3” going into the muffler coming out of muffler small piece of 3” stepped up to 3.5” going into resonator then 3” coming out. Wtf?!
I just did the Borla XR-1 #40086 on a 2017 6.2.   Removed the muffler and flapper but left the rear resonator intact.   Sounds perfect.   I did get an Range device to shut off AFM, so no drone at all!   Still loud on cold starts and when you get on it, but pretty tame at cruising speeds.
This is what I am leaning towards for my truck.  I will need a different part number, I'm sure, since mine is a 5.3.
I ended up ordering a Gibson MWA 3” in and out, and having the flapper delete deal. Having it put on Thursday. Also have a tuner to kill the V4 crap. Hoping it’s louder than stock but not over kill
Post up after you install.
think you would have been happy with a muffler delete though. I kept the resonator just deleted muffler and flapper. Sounds really good. It’s louder then stock obviously but not crazy loud. On cold start it is a little loud and wot it is but cruising it’s not bad and there’s no drone. No helicopter sound when going in 4 cylinder mode either.
You might end up with drone getting rid of the resonator.
Had the muffler put on today and deleted the flapper. It has a nice and deep kind of hollow burble to it at idle. Good cold start and mellow sound cruising around town. Haven’t really gotten on it yet or taken it out on the highway yet though
You left the resonator on?
Yes I left the resonator on it for now. Gonna see how it sounds out on the highway and may cut it off later too. It came stock with a nice 4” Chevy rolled tip that I slid farther out on the pipe and it lowered the tone quite a bit too. I’ll get a good cold start video in the morning and post it
Nice. Look forward to the video. In 4cyl mode are you getting the chopper sound?
I'd delete the resonator if you have the 5.3.   The 5.3's arent as loud.  Had a buddy with a 5.3 with pretty much the same Borla XR-1 but the 3" version, and it wasn tvery loud, even without the resonator.
I did the 12909 Magnaflow since it has 3.5 inch in and out... Removed the resonator, flapper and stock muffler added a dual twin pipe corsa style tip. Also have a AFE cold air intake that brings out some engine sound as well.
2016 GMC Sierra 6.2L...... Love the sound when cruising at 70 barely hear it almost stock even when switching in and out of AFM.... When cruising 30 to 40 very little sound..... Give it some gas where it lives above 2000 rpm and the deep sound comes out. I live in a suburb and did not want to be that guy coming home or leaving to my neighbors but needed it to sound like a v8 when it should.
Sent from my SM-N976V using Tapatalk
    • The “engine hours” display is there because the truck detects the key presence as you were thinking.   My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.   It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue.  If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.    Good luck with it.
    • Carbon on valves would be the least of my worries on a light duty, 1500-series pickup with 357k provided the engine still ran halfway decently. Everything else is likely toast, on its way out, or has already been mauled to death by cheap mechanics and backyard fixes. Those kinds of trucks nickel and dime a guy to death.   I wouldn't think having the top end cleaned once or twice would be a big deal on a 5.3 but maybe it is?
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
