I saw, somewhere, where they relocated the antenna up the inside of the passenger side A-Pillar, from inside the engine bay.  Puts the tip up high, part of the reason why the antenna under the hood get terrible reception.
  • 2 years later...
Sorry to bring up and old post. This is a pretty cool mod. I remember doing something similar on my 2002 Silverado back in the day! Here we are 20 years later and I'm going to do the same thing on my 2022 Silverado!
Edited by fondupot
On 1/1/2020 at 4:28 PM, curly said:
You truck looks great... much cleaner!
I did this a few weeks ago but had to put the antenna back on (rural area and the one radio station that I normally listen to for a morning talk show would not work at all). I guess I'll have to go with a shorter antenna so I still have reception but don't have the overly tall antenna in place. Has anyone tried one of the HD antennas that appear to be shorter?
You would think that GM would not use an antenna of this style because these trucks look much better without it and they have proven with other GM vehicles that it is not needed (can be integrated into glass, etc).
One if the reasons for the length of the anntena is so you will know if you are about to hit your pretty truck on something to low to drive under.
If using your antenna to gauge roof clearance you might be cruising into some shady area. Backup and keep the truck looking purdy...
  • Haha 1
Actually it's because most truck customers live in rural areas and the long antenna is better for bringing in distant radio stations. There was an article I read somewhere a while back with a GM engineer about this.
That's comprehensive.
  • 2 years later...
I love this, nice and clean.  I have a shaved antenna on my S10 and actual mast is under the dash but my reception isn't great.  I think I will do this to my ZR2.  I always hit the mast when cleaning snow from my windshield, even the shorty one I have gets in the way from time to time.
    Smitty462
    Smitty462
  • Who's Online   5 Members, 0 Anonymous, 703 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
