10 hours ago, Cpl_Punishment said:
Given that you can't even get the bench seat with storage in the Custom, I highly doubt that.
That was my understanding but it is possible i’m wrong. When the 19 elevation came out i paid no real attention to it because it was in the extended cab version only here. I thought it was a dressed up base model similar to the custom.
It’s more like a RST, SLE, LT. The cool part about the Elevation though is that if you do opt for the 5.3 you still get the 10 speed. (Pretty sure it’s like that on all 5.3’s for 2020 with GMC)
I keep forgetting that Elevation was double cab only in the U.S. for 2019. In Canada, for 2019 it was actually a separate trim level, rather than an SLE appearance package and could be had in double or crew cab.
I will admit, when I first looked at the Elevation, I thought it seemed stupid to spend SLT money on what's basically a glorified SLE. However, I've come to realize that I hate chrome. So if I were buying a T1 with the 5.3, I would go for an Elevation and if I went for the 6.2, I'd pick an RST.
Yeah, SLE and up gets the 10 speed with the 5.3 for 2020. On the Chevy side, you have to go LT TB or HC to get that combo.
Like Ford and Ram. I wish you could get each trim level in painted bumpers and grill. Again with my comment about getting rid of Mary.
I ended up with chrome on my Tundra because the SX package that makes everything body coloured is only available in black, white or red and my wife said no red trucks.
Toyota does some weird stuff too. My neighbor across the street from me has a Cement Tundra and it has a chrome front bumper with a painted rear bumper. ?
Edited by spizike9
18 hours ago, redwngr said:
RST and LTtrailboss are postioned between LT and LTZ
Traditional LT= SLE and LTZ=SLT
Elevation is between SLE and SLT
So, if you consider Elevation to be like RST, then the answer is yes.
The AT4 is positioned between the SLT and Denali, which would be like being between LTZ and High Country.
At the end of the day, the are all just different GM trims. 14 trims in all, for the 1500 series pickups.
The chassis are the same for both divisions.
Thats a pretty good indication. But I wouldn't necessarily put the elevation at the RST trim. My father in law has the custom trailboss and my co worker has the elevation...after seeing both I'd put the trims almost equal (custom/elevation)...GMC will always come better equipped base. The RST seems to just be in its own nitch in the market. A highly equipped LT w/ color matching if anything. I have a 19 RST
  • Haha 1
Elevation comes with DFM and 10 speed, you can get bucket seats, heated steering wheel/seats. Actual storage in the bench or bucks seat console. Rear seat storage. Rear sliding window Basically you can get everything on a Elevation you can on a RST except the 6.2. You can even get the 3.0 Duramax.
Sorry, it’s not a custom. It’s as you said. A high equipped LT (SLE) with color matched exterior.
Edited by spizike9
Maybe the 2020's but the 19's that my co worker has as well as every one that I saw on the lot was bare bones.
You do realize that you can get a bare bones RST too right? Each trim has anywhere from 5-10k in options you can put on them.
Yes my good sir I do!
Or more.
Which is why it's so hard to compare different trims by looking at 2 trucks.
Near impossible to know what was standard on the trims and what was optional.
If a person had enough knowledge to know what was standard/optional on the two, then they wouldn't need to make a side-by-side comparison.
Or how if you want to get their premium colour (army green for 2020), you have to shell out $20k extra over the base SR5 (i.e. more than a Platinum) for the TRD Pro, which is missing a lot of features for the price point.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
