No, but footwell lights would be very very nice.  Surprised they don't have them.  Interior lighting is the one mark they missed in my book.
  • 3 weeks later...
I would love to add this lighting, how did you do it? Did you connect them to work with the doors (off when shut, on when open)?
  • 4 weeks later...
Hate to revive a semi old thread but just curious if anyone came up with a solution to the TERRIBLE interior lighting? Even when all lights are on it is very hard to see anything around the centre console area. The lights seem to point towards the driver/passenger seat but nothing shines down the middle making it very hard to see anything. Cant believe they missed the mark on this.
Edited by Chrisd534
Bought some 3 light led strips and wired them into the 3rd wire (gray) of the white colored plug under the dash closest to the driver’s seat. Works great.
  • Thanks 1
This is just for the footwell correct?
Im referring to the terrible LED's where the sunroof controls would be. Doesnt even light up the cupholders if i'm fumbling trying to find something
In the RST, along with the two passenger lights the roof console contains a recessed high intensity LED pointing straight down lighting the floor console storage area; the arm rest console bin also contains LED lighting that illuminates when you lift the lid.
I was wrong about no LED down the middle.. the one down the middle is freaking tiny though and provides almost no light..
  • 4 months later...
I'm looking to give this a shot. Can you provide the link to the lights you purchased?
Thanks
  • 8 months later...
Was thinking of LED interior lighting change/upgrade (*blue or red*), surprised nobody has done this to the new body style interior! If anyone has, and can let us know where to buy from that would be great!! :)
Doable if you want to add additional lighting and connect to the stock lights.
the factory interior lights are SMD LEDs soldered onto the circuit boards inside the upper consoles. anything can be done with enough skill and money, but for all practical purposes they are not replaceable.
I added some bolt style LED lights to my upper console to supplement the factory lighting in addition to adding floor lighting. the interior is much brighter now!
one nice thing about the factory interior lights at night when you open the door the light actually shines out the open door and illuminates the ground outside (somewhat at least) but its totally inadequate to actually light up the interior.
    • I had a little bit of time before I left for work this morning, so I plugged the scanner back in, and I selected Chevrolet Silverado instead of GMC Sierra, and the very first option was for a 2026 so I selected that one and I seen at the bottom it had the option for psi change unlike in the 2026 GMC Sierra, I selected that option and it took a little longer than the usual vehicle not supported, and sure enough I got into it, and it let my change the psi values.. I no longer have the low psi warning light!   Thank you for recommending me to try it under Chevrolet instead! I can confirm this device does work for a 2026 GMC Sierra 2500 hd 6.6 diesel  just have to select Chevrolet Silverado instead of GMC Sierra.   Maybe I'll contact Autel and let them know of that issue and maybe they will fix it for the GMC option  because some people probably return the scanner due to it not working under GMC Sierra.
    • I just did a little bit more research, and it seems that this Avalanche is not a Global-A vehicle, because the charts seem to list several models that were Global-A starting in 2010, but the Avalanche is not on there. And even similar models such as the Silverado are not on the Global -A platform until later in 2013. Please correct me if I'm wrong.
    • Yes, the 2007 is a GMT 900. Originally I had ruled out computers/compatibility as a problem because I did not change over any computers, only the engine. I know that the motors are different codes, but it seems like the lmg to lc9 is a fairly common swap, at least from what I can read online. I'm using all the wiring and sensors from the 2010 vehicle, as well as the computers (the only exception to that being the MAP sensor).
    • Real Truck handles the warranty via GM.  We don't submit a warranty claim with GM, we have to submit it with Real Truck with a specific email/phone number.  Real Truck determines if the issue is covered or not based on the issue and pictures submitted.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
