I searched and couldn’t find if anyone has done it. I know boost automotive makes a kit, or you can just buy the $1 diode, but has anyone actually done it where you wired the fog lights to come on with the parking lights? Pin 10 to 22.
If so do the fog lights come on when you remote start the truck? Also I’m assuming they stay on with the hi-beams since they are wired with the parking lights?
Someone posted a video on this. Maybe helpful.
I saw that video already thanks, it doesn’t really speak to every time you auto start though.
He mentioned in the end @5:22, every time there's power to the running/parking lights the fog lights will come on. I'd expect that to happen during auto start, or even just on the unlock from the remote or door.
True, i wonder if that would have a negative effect on the fog lights
Yes they come on every time the parking lights are enabled. I used the diode method. And yes they come on while remote starting at night
Do they flash with lock/unlock??
What’s the diode method?
I did the boost auto mod on my Sierra. They come on with my running lights when remote started. I don’t believe they come on when unlocking. Granted I rarely unlock with the fob and use the keyless buttons on the door.
No they don’t flash with unlock. Only the turn signals flash not the marker lights.
Just use a 3 cent diode wire and connect the same two wires that the boost is essentially connecting. Just a less costly way. I've done it to my last 3 trucks over 7 years and no issues ever.
Here is another option fleceperformance.com/all-lights-on.html  small circuit board with a diode. I used pin 10 and 22 referred to boost for which pins to use for different functions.
so bridge the 10 and 22 pin location with the diode wire?
  • 8 months later...
I understand a diode only allows current to flow in one direction, is there a certain spec/size diode you recommend using?
I would love to do this to not only my fog lights so I can have them on with Hi-beams.   But I'd also like to run a jumper to the work lights on the mirrors to use them as ditch lights when needed.
Using a couple of stick pins, some wire and a switch makes this mod a lot easier. The stick pins will slide in much easier than the leads on the diode. The switch (connected to the wire, and not seen in the picture) allows quick and easy deactivation of the mod for state inspection, etc.
    Tbhats2130
    Tbhats2130
  • Who's Online   5 Members, 0 Anonymous, 1,046 Guests (See full list)
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
