Has anyone missed the interior roof mounted grab handles that used to be on my 2017 3500? I wonder if they can be added back? Was a nice place to rest your hand while riding.
Also they did away with the sunglass compartment where I used to store my airbag controller. I wonder why those two things went away?
I hope my 2020 3500 SLT  DRW. has the grab handles that's how the wife pulls her self up in .
Also missing the visor mirror lights, my wife is not happy with my $ 62,000 SLE..... And no LED brake lights or front turn signals at this level?  There are cheap compacts on the road with nicer options.
My 80k denali should have adaptive cruise control. Unfortunately it doesnt. But my honda crv does. Can never understand their reasoning.
I also miss my ashtray (for coin storage) and the second level of door pockets that were on my 2017 3500 but are now gone on 2020 3500. Also wish you could set seat AC or heat to just stay wherever you previously set them to. Also auto high beam doesn’t work if you turn fog lights on(which don’t stay set to on either).
I just traded a 2017 F250 Platinum for a 2020 GMC 3500 AT4.  Ford really had their tech figured out, I am disappointed in these shortfalls. No massaging seats either, those came in handy on long trips as a little pick-me-up.
resurrecting this, has anyone figured out if it's possible to add the ceiling mount grab handles? especially for the passenger side DW is really missing this.
Grab handles are on the pillar now. I am sure you can go to your dealer and find the handle part in your interior color and figure out how to mount them. There should be a thicker metal brace running along the edge. As for someone who said vanity lights are missing, Do you mean the ones in the visor as my '21AT4 has them. If you get the SLT and up trim with the center console there are more than enough storage cubbies for the remote. My question is why the phone charger was moved to the console head near dash and taken out of the console compartment cover. My wifes Iphone barley charges because of the size.
Agree with the charging pad location, sometimes I wonder what the point is to the surveys they send out.
I can't imagine people suggested moving the charging pad to that location. As far as the grab handles, I believe
someone mentioned it may interfere with the side airbags. I pick my truck up today and will pose that question.
picked my truck up and asked the service tech about installing grab handles overhead. He said GM does not sell parts to install this, nor endorse this. he said check on line but doesn't believe there as any after market kits for this, and the side airbag may be in the way.
So unless someone on here knows of a way to do it (please share) we are SOL.
Edited by obazsm
As mentioned above, additional handles would proba ly interfere with the airbags.  With low production numbers, there isn't much after market support for these rigs yet, even if they wanted to risk liability of compromising a pillar integrity with drilling, or interfering with an airbag. I still have my fingers crossed for somebody to crack codes for tuning and electronic mods. Probably not likely, due to the small market.
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
    • T3's and Ibuprofen. I do have a cryotherapy unit (ice machine) and a lift chair that will allow me to raise my legs above my heart.  There are topicals that I can use once the wound is fully healed.
