I Have ~6,000 miles on my 2020 Silverado Trail Boss and have had an intermittent issue with my infotainment screen. Occasionally when I start the truck, The screen is illuminated but nothing is working or showing. I try several things like pressing and holding the power button, turning the truck off and back on, nothing works. The screen stays like this even when the truck is turned off. When I put it in reverse, the back-up camera comes on but there are no lines on the screen. When I put it back into drive or park, the screen goes black again. I drove 45 minutes to work and the screen stayed this way the whole time. When I started the truck to come home after work, everything was back to normal.
Anyone have this happen to them?IMG_4304.thumb.JPG.11ab3e26fe8c15e676510a1c7963fdc9.JPGIMG_4299.thumb.JPG.f92affdd58a97efe008bb60c4ad56591.JPG
Not quite that but my phone iPhone Xr when plugged in for car play doesn’t play music though it says it’s playing, stuttering screen and general slow/no response from the screen.  Playing music through Bluetooth is fine.  Took it in and he tech plugged in his 6s and it played no problem.
Mind you my iPhone had zero issue with my 2018 Sierra and still works fine in my wife’s ‘17 Malibu.
My radio does the same thing here and there where my phone says it’s playing but nothing is coming out to radio. I have had two trucks with non Bose and 2 with the Bose  and the Bose runs flawlessly but both trucks without Bose must have some software programming that gets stuck here and there! I noticed that if you switch apps on your phone like going from pandora to YouTube if you shut down completely before opening the other it limits it getting stuck!
My Custom does the exact same thing
have owned it 5 months and has done it at least 3 times.
I’m done taking this thing in. I wish it would blow up. Miss my Ram.
I have had this happen once, but also had it where it just decided to play over the air radio and either satellite radio or something from my phone at the same time and it wouldn't let me change it.
Also had numerous issues with it just deciding it wont let me have any volume or changes the volume settings over bluetooth randomly when I get in the truck.
Usually restarting the truck will fix it. For the first two issues, it took a couple hours foe the first and the second it was working again the next day. Lots of little issues like this and next to impossible for a dealer to fix them.
This may help you guys.
have had mine for a week. 2020 GMC 2500HD AT4 Duramax. I couldn’t figure out why between short key cycles I would lose all audio and everything in the IC screen expect for the main info page with speed and trip etc. nav, audio, phone all blank. Center stack screen shows me that the Sirius radio is on and the songs change but I have zero audio, no audio for Bluetooth or apple car play either. I tried key cycles, opening and closing door etc....
WELL....its apple car play. On these short key cycles I would leave my iPhone plugged into the USB port. Drop my kids off at school and come back out to no audio. Now when I have these quick trips I make sure I unplug my phone and everything functions like it should. It takes 3-5mins for it to reset with truck off and door opened if you do leave it plugged in and this happens to you. I let my dealer know of the issues I was having but plan to call them today and let them I know I figured it out.  Clearly they wouldn’t of had these issues if I dropped it off to be looked at. Maybe this works for you. Good Luck
I was beginning to believe same thing but dealer said GM asked me to not plug my phone in at all after one of their can't replicate it so its not broken diagnosis',  so I didn't for 2 weeks, no cable, no bluetooth and it still acted up over those 2 weeks. Finally got them to get a GM engineer to be at dealer to check mine out, its been 3 weeks there this time, finally got to look at it and I was told they sent the test results to china. They are waiting to hear back from them to see what to do. Pretty sure after all the replacement parts they swapped out and the troubleshooting over the previous 8 months, this isn't a CarPlay problem.
  • 5 months later...
I pulled the infotainment fuse 2 (2020 Silverado 1500 LTZ) waited 30 sec plugged it in booted back up. No idea what root cause is but it did work. I believe in here I saw a host of other issues regarding traction control parking brake etc. Solved this by applying P brake putting in drive and “driving it off” style of release.
I’ve had a black screen a few times. Curious what software version you guys show?
2020 Denali and I’ve not gotten one update.   Still on a September 2019 release.
I have had the same issue probably a dozen times in 5k miles. More annoying than anything else. I only use bluetooth, nothing plugged in via cable.
I mentioned it during my first oil change, and they updated the software to the latest and greatest, but it has done it twice since it was "updated". I'd have to check and see what version I have.
What version are you showing for the infotainment system?
Mine is still the original from Sep 2019.  WTF?
My infotainment issue finally got resolved.  The CarPlay issue I noted above was due to a bad plug from the USB port to the head unit.
  • 7 months later...
I have a 2019 silverado lt. Infotainment system will crash when using apple carplay intermittently but especially when using gps and using the phone. I have most recent updates on info system and iphone 11. I have brought my truck in 4 times. They replaced the radio and it still occurs. Completely unacceptable, extremely dangerous to the driver. Really making me rethink chevys hunk of junk!!!!!!!!
I have the same issue unfortunately I have a few others in addition to the screen going black. It started with poor audio quality, skipping, poor reception both plugged into phone and bluetooth.  unfortunately it wasn’t just the CarPlay it was doing it with Siri and regular radio as well as my phone calls. I thought is was just needing update. I have been on the phone with OnStar trying to get it resolved, they checked my radio signal, made sure my phone tower location was set to the correct one for my area, they boosted my signal strength over the  air while on onstar call and rebooted the whole radio ota. But unfortunately no matter how many times I ask them to remove the Internet from my free trial they never do and my phone has to be several feet away from my truck in order for me to use it without turning off my Wi-Fi.  Just forget wireless settings on phone? Nope. Somehow it possess it back into functioning??? WTAF?!?!
After all of the troubleshooting with technician, he determined that my whole infotainment system needed to be replaced. I have yet to hear from anybody but do you have a case number from a couple weeks ago.
This Friday I had a scary moment, I had my cruise set to 62 and my truck just accelerated up to 70 something before I brake checked it down to speed, the screen went black on the infotainment system, and my information centre in the instrument cluster went to trip counter. I had to stop the truck and turn off the ignition in order to reset it to function. Now however every time I drive it it reverts back to trip on the instrument cluster upon start up.
I will be calling my dealer and find out what the hell is going on as this is becoming dangerous. And no I didn’t accidentally press the button up too long on this cruise control,  I  only pressed set by getting to the desired  by pedal and managed to hold set speed a couple hundred feet B4 it crapped the bed.
I had something similar to this happen on a previous vehicle, and that ended up being the main computer module. They told me it was caused by leaving my key fob in my truck while in garage, so I no longer do that. It never once ran away on me though.
This is the second strike for this truck. From day one my lane assist did not work and it was found to be a faulty front driver side camera which was replaced.within a week of ownership. however I have tested it after it’s been fixed and I can hit the gravel on the other side of the road before self correcting as there is no indication at times of lane departure. 😱 I sporadically get a seat rumble and I’ve checked my settings, there’s just no rhyme or reason.  My automatic engine shut off is a joke. It starts and stops and starts and stops awaiting at an intersection so badly that people probably think I have turrets of the foot. Now its common practice to turn off upon start up.  Jeebs
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
