P0324 no knocking
Current truck, bought at 60k miles, currently have 95, whipple 2.9 installed at 76k , current issue p0324. No other codes, loss of power, garbage gas mileage, suspect either knock sensors or pcm as that's the only thing I can find on this topic. I have zero noise coming from the engine and still achieve 13 psi from the blower. Not losing coolant, or oil. Loss of power obviously coming from the car pulling timing as it's in a safe mode. Just need advice on whether or not it's going to be the pcm or the knock sensors themselves. Any advice would be appreciated.
Btw the truck is strictly 93 octane. Screenshot_20200224-032002_Snapchat.thumb.jpg.bb98e3b7cd9c84db60383b4c9b6793b6.jpg
Having a PCM issue is the worst case issue and normally is highly unlikely. They typically don't just randomly fail like that and give you one issue like this code. You'd have more systems errors if the computer took a dump.
I would inspect your knock sensors, check the connectors and wiring. Make sure they are getting the correct voltage at the plug etc etc.
Went ahead and ordered 2 knock sensors will be here in the morning. Thanks for the reply, once you start searching you can kind of get off track.
03-10 Update as there really isnt alot of information on this code for our trucks,
Knock sensor did nothing to solve the issue, from what I was reading a bad pcm will cause this too, however I went ahead and changed my plugs out and found one that was loose . Went ahead and swapped out all plugs and she's back to running like a train. I was only getting the p0324 code no misfire codes or anything.
Ignition system was my guess or the timing was off. I 'm glad you got it fixed the torque spec on the plugs are 25 Ft/Lbs. or 300 In/Lbs. just in case!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
