Rear differential size?
ShortyMatt
There are 12 bolts on the cover of my 2018 sierra 1500 5.3's rear.  Does that by default mean I have a 9.5 differential?
I hate asking the internet but I've spent hours googling and I'm getting so much conflicting info.  Normally I can cross check enough sources and figure out what fits.  Some vehicle specific sites are pointing me at the 8.5 which doesn't seem correct.
I'm doing a posi by the way.  Should be pretty sweet.
Thanks for your time.
It's either the 9.5 or the 9.76.  Anything with a 5.3 has either of those 2 axles and only the trucks with V6s had 8.5's.
If you have the NHT option code in your glove box it's the 9.76 and if not otherwise it's the 9.5.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
