Thanks all, I have ordered a cargo bar.
I did look at altering the existing gate, but it was almost 8 inches too short.
Was leaning towards the 2x6 or 2x8 solution but with the bed being wider than it is long, storing it out of use would have been an issue.
Hoping an adjustable bar works well for the best of both worlds.
  • 2 months later...
I would love to find one too. First time owning a truck, Got a 2020 Sierra AT4. A friend has a dodge RAM and they have ridges all through the side walls of the bed where a spring loaded divider wedges. you can adjust it to whatever depth you like. Didn't think that far and liked Sierra more than Ram. Now I can't find anything similar.
The only thing I have found is a U shaped bed extender kind of divider.
  • 8 months later...
On 4/9/2020 at 5:21 PM, Duramax3oh said:
This looks fantastic. I may have to do this myself!
Yes I did this to my 2017 Sierra ... do you happen to have the measurements for the new body style ... would like to do it to my 2020 Silverado .. I guess I could measure but if you have the cut length that would be awesome for many...
On 4/9/2020 at 5:05 PM, Coastie said:
can't think of a way to hinge it and still be sturdy enough to stay in place.
For a 2 piece design just hiinge the section of  at the top not the side.
Edited by Descartian
Quote
Copied Ryno12s idea with the 2x6 lumber.
Cut the center  of the long cross board and added a 4'" door hinge on the font side.
Push to front to fold out and pull to rear to fold in.
The short legs against to tailgate and the long ends against the wheel wells keep it in place
Fold ups and stows nicely in the truck when not needed.
Edited by Mike_F
Simple but functional modification... I used two 2x6’s
On 4/16/2020 at 10:00 AM, Fltmech said:
As someone said before, a ratcheting cargo bar works good.
If you plan on adding a bed cover, look into a roll-n-lock. The make a cargo divider similar to the one you have that works with the cover, slides and rotates out of the way.
I've got the Roll N Lock cover and cargo manager. It is going to cost you around $260 to $290 for the cargo manager but it works great. I have a couple of folding crates that I bungie to the cargo manager for groceries. When I get home I just carry in the crates.
    ncleg
    ncleg
  • Who's Online   3 Members, 0 Anonymous, 1,479 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
