Brought home a 2020 Sierra yesterday, upgraded from a 2003 Ram 1500 I had for 17 years.
Found out my bed gate is way to small for the new truck and the bungee net I had, for lack of a better term, is just plain stupid.
I'm looking for something nice (and ideally not $300 for a new gate) that basically stops groceries from sliding all the way forward, and easily removes and stows away in case we need use of the full bed on a whim because my wife doesn't plan things out as much as I do.
too small
too stupid
Mine has full  corners not tapered like this one. When folded in it holds grocery bags from sliding.
Edited by Ralph Ciardullo
2x8 or 10 and use the pockets, how i keep gas cans in the back, take out when need the whole bed
Just saw those pockets built into the bed, measured the back at 72 and the front at 71. Then I measured the bed length, couldn't believe they won't fit for storage when not installed, the bed is wider than it is long. I keep forgetting that coming from that old Ram with the 76 inch bed. Guess I could make them in 3 pieces so they break down, can't think of a way to hinge it and still be sturdy enough to stay in place.
Edited by Coastie
I did the 2x6 thing and sprayed it with bed liner in a can. I also made moveable pieces to use as dividers.
This looks fantastic. I may have to do this myself!
Put in at angle when needed to carry but not have installed or use upper groves to keep board up in storage I use 2x8 and cut notches for string trimmers to keep out of the elements under tonneau.
I have used a tractor trailer compression rod before the wood just cut it down to size i needed, have seen at tractor supply before, wood works better for me but dont take out too often
Here's a cargo net they say fits your bed...Bed Cargo Net with GMC Logo
Another thought...If you're eventually going to be getting a bed cover/Tonneau cover, you might look at the Roll N Lock retractable covers. I have their M Series, and their Cargo Manager. The Cargo Manager looks a lot like your old one, but this one attaches to the bed cover rails and rolls back and forth, with the ability to lock it in different positions.
I really like mine, and it looks like you keep your pickups a long time like I do, so spreading out the cost of the tonneau cover and cargo manager over 16 years...makes the initial cash outlay a bit more palatable.
Awesome! I like that. Thanks for posting.
too small
too stupid
As someone said before, a ratcheting cargo bar works good.
If you plan on adding a bed cover, look into a roll-n-lock. The make a cargo divider similar to the one you have that works with the cover, slides and rotates out of the way.
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 1,173 Guests (See full list)
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
