Hi all,
I just bought a 2020 Trail Boss, and I wanted offset wheels, but I like the rims and tires the truck came with just wish I can get it with a bit of a wider stance. Has anyone used any wheel spacers and are there any concerns with these i should be aware of? I dont want to use them if I am going to cause other issues. If you have any recommendations on a brand/type I should get please let me know too! Thanks
On 4/14/2020 at 9:57 AM, Matt Boyce said:
Hi all,
Do some research, but avoid the cheap ebay ones.  From my readings (albeit brief) are to get hub centric spacers instead of lug centric (https://www.liveabout.com/hub-centric-vs-lug-centric-wheels-3234497) so the wheel/spacer is supported by the hub.
Love my 2 inch custom billet spacers, $67 each with nuts shipped out of Tampa, FL. Have pulled over 8k many times with spacers. Stock wheels and tires. 1.5 level, 3 inch rear blocks.
Not the best angle, but those are 1.5" spacers from amazon. About $100 shipped.
I've been running them for 3 months, with a large trip to Florida from Michigan, hauling a bike trailer.
No issues. Locktite.
1 1/2 hubcentric spacers on stock wheels. 15k miles and no problem at all. Much improved the stance at a very minimal cost.
What lift do you have and what are the tires?
2" Trailboss lift, 1 1/2 motofab under strut level in front. 305 55 20 BFG ATs on stock 20x9 Trailboss rims painted black
  • 3 months later...
2020 Silverado Custom trail boss - 1.75" Bora Wheel spacers , perfect fit, no clearance cutting required with 18" rims and stock tires.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
