Pretty sweet, just put mine in. Noticed that the stock lights have K2XX stickers on them. That might mean that 2014-2018 guys could use these logo ones too (if the aim is similar). Not sure if they are being sold that way or not.
No nighttime pics yet, just instructions, invoice and side by side with stock on the left for anyone curious.
2433F381-FDFC-43EF-BA8D-2EA01323ACE8.thumb.jpeg.602c7e8fdf4c2c473564aed1f9d86a82.jpeg0404EFB9-1064-45F6-A06E-84A8CACB3D7F.thumb.jpeg.b903380c427351bfca465d6ddc58de23.jpeg7F19DB54-7CCE-432A-8810-19737AFA927F.thumb.jpeg.4e75775f8d1215ac34a5e6bc7b25bacf.jpeg
13 minutes ago, OnTheReel said:
Looks good! Does it illuminate the ground and the area around the logo better than the stock lights? Did you get those through ShopChevyParts?
Edited by ausomecasey
GMPartsStore.com
If you google the PN, 84408372...their store is the top hit with a 10% code. Best price I could find when I ordered ‘em last week.
All of the light is concentrated to the bowtie, so none of the ground around it really gets lit. I never really relied on the light from the originals but if you do, this mod ain’t for you.
The light output was so poor on my OEM puddle lamps that I didn’t even notice them, when I saw these lights were available I had to go and check to see if I even had puddle lamps as I was unsure if I did. I’m much happier with these lights, GM did well with them.
On 4/30/2020 at 9:26 PM, Opiedeegs said:
I just installed during the day and couldn’t see the light now that the sun has set they look greatbd58f394816b95ee2172c73f7e2a5b03.jpg
This looks great!! Are these the oem ones?? I love the blueish tint to the lighting.  What type or what did you do to get them to shine that color?
Well I'll be go to hell.  First I've ever seen them/that and I thought I knew everything ?.  I can't believe I never saw them or read about them despite all the magazines I subscribe to and forums I read.  You learn something new every day!  Thanks guys.
GMC part number is in the link of the very first post.
GMC Puddle Light Kit 84408373
Ebay has it for $95
GM Parts direct for $102
Are there any other options for this mod that just include a brighter light to illuminate more area?  I really don't care for the Bowtie, but like the idea of brighter light covering more space.
Thanks!
I purchased mine from shopchevyparts.com get the discount. They are for Chevy LTZ and High Country options or the top tier GMC truck brand. They are plug and play, pop out the OEM and insert these they are really bright and seeing the bowtie shining on the ground after dark when unlocking truck is sharp. I installed mine only small screw driver required very simple. They install in outside rear view mirrors.
Edited by Hi-Ho Silver
added information
Anyone install the GMC version and notice the passenger side being out of square with the truck?  My drivers side is nice and parallel, my passenger side is EXTREMELY unparallel to the truck.  I double checked installation, made sure the mirror was fully extended, I think I might have to exchange it!  I know the pavement is uneven in the photo but trust me, its bad.
 I have a 2015 Silverado. I have the circle cut out is in the bottom of my mirrors. But I have no existing puddle lights. Can I still buy them and just plug and play? If so, what is the part #?
Edited by ChevyDivision15
    • They’re not the same wiz as 10-15 years ago.  QC has fallen pretty hard.  The XP line was never good though in the first place.    https://bobistheoilguy.com/forums/threads/wix-filter-rusted-through.386492/post-6991372   https://bobistheoilguy.com/forums/threads/i-ve-used-my-last-wix-filter.27299/   https://bobistheoilguy.com/forums/threads/looking-for-a-better-replacement-for-wix-51258.403977/   https://bobistheoilguy.com/forums/threads/convince-me-in-using-the-purolator-boss.401537/post-7420147   the forums are littered with posts and examples of not great wix filters the last couple years
