1 hour ago, GTPprix said:
Contact us from the website if you'd like to discuss all of these are custom at this point but I know one of you said you reached out but we did not get anything just an FYI.
I tried to contact thru your website. Twice but no response. How about a phone number to call?
Found it in spam, one this morning and another one about 10 minutes ago you should see a reply now; sorry about that!
Edited by GTPprix
I'm in for the pics of exploded driveshafts at 120+ mph.
Please post them.
Please post them.
Me too, iam in on that one and what's left of the truck.     :idiot:
Please post them.
Probably won't see any from the new body style trucks with the big 4" diameter DS. Especially those with the high capacity towing package.
On 7/15/2020 at 7:02 PM, GTPprix said:
Yup! Just like we do for the K2's and it we've done it on the T1's as well :)
I'm in if I get a T1...
The drive shafts have been pretty much the same since mid 2000's for the aluminum style. They are that 3.5 to 4in size. The single cab long beds with aluminum shafts in some of those years got massive 5in shafts but that's not really the point here. The metal is paper thin, ever seen a shredded shaft??
If drive shafts from the K2XX body style can break, so with the T1XX trucks. They aren't going to make it better very much different when the exact same drivetrain parts are carried over from the previous trucks.
I am much more concerned with runout and weak U-joints and incorrect u-joint bearing cup seating which does lead to excessive shaft runout than I am about the shaft itself. IF you have qualms about your drive shaft, put it up on the rack and check runout front and rear with a quality dial indicator. Excessive runout will destroy stuff muy pronto and you will feel it long before it blows. A thin wall drive shaft can be very strong but a truck built for a towing capacity of 12,000 lbs isn't going to have a weak DS. If these drive shafts are that weak they would twist in two before you could even get a heavy 12000 lb trailer untracked.
Edited by Stephen L. Pannell
Most people I talk to that have had shafts break or the ones you see on youtube dyno runs don't feel the vibration until right before it goes boom. There's a thread on performance trucks.net with a guy doing 95mph and it just went with no warning.
I'm not saying they are weak in the fact that they can hold up to heavy towing and they do just fine even with 600hp. It's just the speed the shaft turns that grenades them. To me it's not worth the time to remove the stock shaft and have it taken to a shop so they can spin it up. Replace it with something better that will handle the speed without any question.
The underlying and root problems of driveshaft failure has been addressed several times in tech bulletins and other research. Aluminium centrifuges spin at a rate of 12,000 to 90,000 rpm or up to 1500 rps and don't blow up. Drive shafts spin at a fraction of that. Research has shown that most failure aside from external damage like high centering on a boulder or something, are caused by several other factors.
1. U joint sync
2. runout caused by worn or defective drive spline which is the main cause of u joint sync problems.
3. shaft out of balance.
4. incorrect drive line angle. can we say lifted trucks
5.  improper seating of the u joint bearing caps in the yoke cradle
If any of these items are out of parameter then high rpm harmonics can and will destroy the shaft.
Plenty of data on how to check these items and repair or correct. One of the main culprits has been output and input spline misalignment, wear and just poor quality in manufacture from 3rd party outsourcing of parts. There are GM tech bulletins on it as well.
I'm not saying that GM isn't at fault because they are. Cheap labor in Mexico perhaps during assembly.
There is also an android app called NVH that can be purchased that will identify and pinpoint vibration locations and root causes.
NVH is expensive at $400. Don't think for a minute that NASCAR and NHRA top teams don't have tools to check and fix these errors.
These types of driveline vibrations gone to the extreme will destroy any long shaft regardless of what it's made of.
Also google youtube videos of how to check driveshaft balancing. There is a free phone app that will measure sync angles for the u joints.
Well I’m getting a T1.   So I would like to raise/eliminate the top speed governor please.
My 19 crew cab 4x4 stops at 112... I just want to do 125.  My diff is 3.24.  Police Tahoes are 3.08 with shorter shafts... but there is nothing special about their DS versus a regular Tahoe.  I'll take my chances in the 120s, and will gladly post pictures of any carnage.
Some have posted that the limiter set by factory based on the tires it was born with.
I can't verify,
but...police tahoe probably has different speed rating tires than crew cab 1/2 ton..
White Auto and media advertises a speed limiter delete on the Modifications forum, but I also contacted Diablo Tune that said their tuner should be out in 3-4 weeks for my 2019 Silverado 6.2L
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
    • I would not argue that with you. It would be pointless to argue against the truth and you speak the truth.    My question and in fact the entire point of this thread is an exploration into the levers of wear which happens no matter how well we maintain our powertrains.    Some of these levers we exert a good deal of influence over which can and do result is lower wear, longer powertrain life. Some others we are sort of stuck with.    An engine is typically done when the ring to bore seal no longer is able to do the job effectively. Normally the first thing to go in a engine otherwise well maintained and adult driven is this seal.    Looking into the means, methods, products and attitudes that influence the rate of wear seems a worthwhile inquiry to me.
