On 5/10/2025 at 3:32 PM, GETGONE said:
I've run mine to 112 countless times with zero issues. 31K miles and still going strong. Took it to a test and tune and ran about a dozen passes trying various launches, no issues. Best of 14.2 in the 1/4.
Nice time!  If memory serves, that 112 mph problem applied to K2 1500s.  I recently learned that my kids have been exceeding 112 with their GMT900s with 6.2s too!
Driveshaft seems to get a lot of the press, but tire speed rating should be looked at too.
(yes, I realize that exceeding speed rating isn't likely to cause immediate failure...)
Do they know about tire speed ratings?
Speed (and load) rating will also be on the tire.
Factory tires on my '21 were speed rating S.
S
An S speed rating indicates the tire has been approved for speeds up to 112 mph (180 km/h) under optimal conditions. Everyday passenger vehicle tires can be S speed rated, but S tires often prioritize specific performance or function. Many all-terrain LT tires are becoming available in an S rating as that’s the OE spec for many of these vehicles like the Ford Raptor.
This is was on a set of Duratracs I used to have.
Load load rating 109, speed rating S
Current '23 has  275/60R20 115S
So again, speed rating S
My current winter tires are speed rating R.
Speed rating R allows for speeds up to 106 mph (170 km/h) under optimal conditions. Like Q, R tires generally prioritize a particular function or unique performance over maximum speed capability. R speed tires are rare but can be found on some heavy-duty light truck (LT) tires, as well as studdable and studless winter tires.
Edited by redwngr
Speed Rating Miles/Hour KM/Hour Typical Application(s)
L 75 120 Trailer tires
M 81 130 Spare tires
N 87 140 Spare tires
P 93 150
Q 99 160 Select winter tires
R 106 170 Passenger and light truck tires
S 112 180 Passenger and light truck tires
T 118 190 Passenger and light truck tires
U 124 200
H 130 210 Passenger sedans, coupes, SUV and CUV’s tires
V 149 240 Performance sedans, coupes, and sports cars tires
W 168 270 Performance sedans, coupes, SUV and CUV’s tires
Y 186 300 Exotic sports cars tires
Z 149+ 240+ High-Performance vehicle tires
Trail Bosses with the 18" tires are electronically limited to 98mph due to tire rating. The 20" wheel option bumps the limiter up to 112mph because of the S speed rated tires.
LOL. Busted.
My 2000, GMT800, that I still have, has a 128 limit. I have seen 4000 rpm`s in overdrive with 16 inch wheels and 3.73 gears. Poor 100 mph speedo.
16 hours ago, PunchT37 said:
LOL. Busted.
I'm curious what the tire loading label on the doorpost lists as the speed rating?
Edited by redwngr
S. But, this truck has a whole new computer.😉
Thanks.
So if they were installing S rated tires on (at least some) 2020's the original limiter was likely lower/
4 hours ago, redwngr said:
Thanks.
Thanks.
Factory limiter on that 2000 truck was 96 mph.
  • 5 months later...
I have yet to top mine out since I had it unlocked and then tuned it (High Country 6.2 10 spd), but my tires will limit me as I have a brain. But damn the ecm and tcm tune feels great. If anybody is on the fence, just do it. I'm still tweaking some of the shift times to get rid of the sluggish shifts on lower power shifts. mid power shifts are .200 seconds and full power are .100 seconds, tires chirp with only a small boost in pressure and reducing shift times.
Edited by Silveradgo
Who tuned it and how much did it cost you?
Any mods beside the tune?
I tuned it. Only have a K&N Blackhawk intake on it for the sound. Longtubes will be the next go-fast mod.
Edit: I'll have to get a video of the induction noise during the 1-2 shift at like 4.5k 🤤
How did you tune it since you have to send in the ECM last I knew to get it unlocked to be able to tune it.
See my earlier post
4 hours ago, Silveradgo said:
See my earlier post
You have 3 posts. You just said you had it unlocked and you tuned it. That tells me NOTHING. WHO unlocked it? WHAT are you using to tune it? New member sounds like a troll.
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
    • About the only GM that compares well with its competitors through the small to midsize vehicles is the Trax. I would like nothing better to just drive GMs. My wife in a Cadillac me in a Chevy minivan and Colorado. Part of my day is comprised of reading and watching comparisons of automobile. I could buy a car today. I’m back to research the next.
    • Do you have any DFM defeat devices like the Range modules?
