On 5/10/2025 at 3:32 PM, GETGONE said:
I've run mine to 112 countless times with zero issues. 31K miles and still going strong. Took it to a test and tune and ran about a dozen passes trying various launches, no issues. Best of 14.2 in the 1/4.
Nice time!  If memory serves, that 112 mph problem applied to K2 1500s.  I recently learned that my kids have been exceeding 112 with their GMT900s with 6.2s too!
Driveshaft seems to get a lot of the press, but tire speed rating should be looked at too.
(yes, I realize that exceeding speed rating isn't likely to cause immediate failure...)
Do they know about tire speed ratings?
Speed (and load) rating will also be on the tire.
Factory tires on my '21 were speed rating S.
S
An S speed rating indicates the tire has been approved for speeds up to 112 mph (180 km/h) under optimal conditions. Everyday passenger vehicle tires can be S speed rated, but S tires often prioritize specific performance or function. Many all-terrain LT tires are becoming available in an S rating as that’s the OE spec for many of these vehicles like the Ford Raptor.
This is was on a set of Duratracs I used to have.
Load load rating 109, speed rating S
Current '23 has  275/60R20 115S
So again, speed rating S
My current winter tires are speed rating R.
Speed rating R allows for speeds up to 106 mph (170 km/h) under optimal conditions. Like Q, R tires generally prioritize a particular function or unique performance over maximum speed capability. R speed tires are rare but can be found on some heavy-duty light truck (LT) tires, as well as studdable and studless winter tires.
Edited by redwngr
Speed Rating Miles/Hour KM/Hour Typical Application(s)
L 75 120 Trailer tires
M 81 130 Spare tires
N 87 140 Spare tires
P 93 150
Q 99 160 Select winter tires
R 106 170 Passenger and light truck tires
S 112 180 Passenger and light truck tires
T 118 190 Passenger and light truck tires
U 124 200
H 130 210 Passenger sedans, coupes, SUV and CUV’s tires
V 149 240 Performance sedans, coupes, and sports cars tires
W 168 270 Performance sedans, coupes, SUV and CUV’s tires
Y 186 300 Exotic sports cars tires
Z 149+ 240+ High-Performance vehicle tires
Trail Bosses with the 18" tires are electronically limited to 98mph due to tire rating. The 20" wheel option bumps the limiter up to 112mph because of the S speed rated tires.
LOL. Busted.
My 2000, GMT800, that I still have, has a 128 limit. I have seen 4000 rpm`s in overdrive with 16 inch wheels and 3.73 gears. Poor 100 mph speedo.
16 hours ago, PunchT37 said:
LOL. Busted.
I'm curious what the tire loading label on the doorpost lists as the speed rating?
Edited by redwngr
S. But, this truck has a whole new computer.😉
Thanks.
So if they were installing S rated tires on (at least some) 2020's the original limiter was likely lower/
4 hours ago, redwngr said:
Thanks.
Thanks.
Factory limiter on that 2000 truck was 96 mph.
  • 5 months later...
I have yet to top mine out since I had it unlocked and then tuned it (High Country 6.2 10 spd), but my tires will limit me as I have a brain. But damn the ecm and tcm tune feels great. If anybody is on the fence, just do it. I'm still tweaking some of the shift times to get rid of the sluggish shifts on lower power shifts. mid power shifts are .200 seconds and full power are .100 seconds, tires chirp with only a small boost in pressure and reducing shift times.
Edited by Silveradgo
Who tuned it and how much did it cost you?
Any mods beside the tune?
I tuned it. Only have a K&N Blackhawk intake on it for the sound. Longtubes will be the next go-fast mod.
Edit: I'll have to get a video of the induction noise during the 1-2 shift at like 4.5k 🤤
How did you tune it since you have to send in the ECM last I knew to get it unlocked to be able to tune it.
See my earlier post
4 hours ago, Silveradgo said:
See my earlier post
You have 3 posts. You just said you had it unlocked and you tuned it. That tells me NOTHING. WHO unlocked it? WHAT are you using to tune it? New member sounds like a troll.
    DLZ
    DLZ
  • Who's Online   5 Members, 0 Anonymous, 632 Guests (See full list)
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
