Hey, new to this forum. I’ve had a few Silverados and a Colorado over the years and Just picked up a 2020 Silverado. I use this it to pick up pallets of grain once week or so. Inevitably the new kid at the warehouse will bump the forklift into the tailgate resulting in a bunch of ugly dents generally not worth fixing but really annoying.
I’ve searched over the years but never found any type of mod to protect the tailgate so thinking of diy-ing it. Something like a length or pvc with insulation wrapped around it that can hang by straps and hooks right over the end of the tailgate when down. Or a length of 2x4 with rubber.  Removable so it just sits in the bed when not in use.
anyone seen any kind of mod to protect the tailgate or made one themselves? I’d rather not have to use a trailer.
I’ve been usually watching and guiding them from hitting the wheel wells on the much more narrow Colorado but I guess that won’t be a problem. Maybe it’s as simple as that. But seeing as they are usually somewhat or completely high I’d still like a guard lol.
You can always remove the tailgate it's not that difficult.
all the other ones more than likely the forklift operator seems like I'm good and hit harder than you would if it was just your tailgate which is probably going to result in a bent tailgate instead of a dinged up tailgate.
if you're insisting on DIY and you can always split open some pool noodles and create a little bumper over the top of the entire tailgate.
Good suggestion. Thanks
If the person is ramming your truck hard enough to dent the end of the tailgate, a pool noodle isn't going to make a difference other than making the end of the tailgate more visible (which likely is a good thing anyway).  You could put a strip of angle iron across the length of the tailgate, but that'll just move where the damage can happen (as then it could just push in the end of the tailgate more evenly across the tailgate, or it could do something like bend the tailgate hinges instead).
Edit:  Alternately, the pool noodle is a bad thing, because it gives the operator something to aim at...
Edited by davester
When I read this title I thought it was going to be a joke about the exhaust...haha
  • 6 months later...
Make him pay for it. I Bet he will not hit it a second time. They load pellets of tile. Mortar and often lumber and never damage nothing on my Trucks or  Vans. My thinking is personal responsibility. Tell them they hit it they buy it , if they do not like the ideal let them load it by hand.
Sorry to sound mean but its not that difficult.
but getting a metal grill type tailgate might be the best answer , Like the ones for 5th wheel hitch
I grew with the above, they damage it, they pay for it, it will only happen once.
Take a 2x6 as wide as your tailgate and screw a 1/4” piece of plywood to it that is the same size of your tailgate plus the width of the 2x6. Then just set that on the tailgate before they load.
Spray in bed liner?
Plastic throw-in bed liner?
Factory painted bed floor?
Worried about bed floor scratches or just tailgate getting dented when folded down.
42" x 48" pallet (or similar)?
I've loaded 100's of pallets with similar loads and don't think I've ever hit a tailgate.
Maybe the forklift/forks are too small for the pallet size and load being handled?
It's not tough to set a pallet partway in and get another bite to push it the rest of the way -- while staying safely away from the tailgate (or bumper, if tailgate has been removed).
Edited by redwngr
Spray in bed liner?
Agreed on the fact that the operator should be capable, have run lift trucks for 15+ years and never damaged a vehicle but, have seen other experienced guys do it a few times. It’s carelessness IMO not lack of skill.
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
