On 12/7/2020 at 4:24 PM, bharris515 said:
Am I reading this right? The upgrade will include navigation?
"For vehicles without HD radio, the upgrade will also enable it. For the cost, WAMS will also upgrade your infotainment to include navigation as well."
For me, I'll stick to Waze via CarPlay. But for many, that might help justify the price tag.
That’s correct but I think they’re saying adding navigation will cost a bit more than just adding the wireless CarPlay. I’m with you, if you have CarPlay you don’t need factory navigation. I prefer google maps.
I think I'll continue to plug the cord in for the estimated $800.00 cost.  Pretty cool they can do it though.
Damn $800 I’m sure glad my Carplay2air works flawlessly for me. I don’t understand why they would give us a wireless charger but not wireless  CarPlay.
Just now, bharris515 said:
You're lucky with the carplay2air. I've bought 2 thinking the first was just bad and it was a pain in the ass to return. Neither one worked for me.
Yeah I don’t want to update anything incase it screwes it up lol. If it didn’t work I would be buying this module as well. Just not sure why the dealers can’t reprogram our modules instead of buying all new.
I agree. Good news is this is a factory GM module made for the '21. White automotive just programs it with your vin number to work flawlessly in the 20. Worth every penny IMO!
Yeah exactly! I know if my carplay2air dies or stops working I’ll be ordering one of these the same day lol. Having everything wireless is wicked specially if your keeping the vehicle for many years.
I'm another happy White Automotive and Media customer. Their Wireless CarPlay upgrade works flawlessly for me. the price was a bit hard to swallow but once I got over that, I was good to go.
If I spent more time driving my truck it might be worth it to me. I have the carplay2air and it works most of the time - although frustrating when it doesn't. I really only need carplay for long trips to get Waze which also sucks the phone battery dry - so the cable connection takes care of that (I don't have wireless charging).
I have a 2021 silverado 2500hd with carplay wireless projection... my experience is (with just 1k I put on the truck so far)... it's finicky to establish a connection via bluetooth for carplay. I've had waaaaaay more failure than success.  But I have gotten it to work 3xs.  I'm a tech guy and baffled. Wired usb works fine. Onstar has been no help for a solution, they play right out of a scripted play book and in the end, I'm no better off. Disappointing, I've been so looking forward to that feature working seamlessly. Seems more work is needed for integration to flawlessly do what was paid for.  Bummed... Open to any ideas... altho I think I've tried them all minus taking it to the dealer.
What version of iOS are you running? I had these problem at first and as soon as I updated to the newest software it fixed. Also, I'm sure you've tried this already, but try forgetting your phone and then re-adding it. This has fixed some bugs for me too. I wouldn't say mine is flawless but it definitely works flawlessly 95% of the time!
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
