I have a 2019 LT Z71 Texas Edition with the 5.3L in it.
So far I have done mostly small cosmetic things to the ride.  Like the illuminating bow tie, black vinyl stickers on the bow ties in the steering wheel and wheels, etc.
I do have a Black Widow Venom 250 Muffler installed.
I just ordered the JLT catch can today and I kind of have the itch to do something else to the ride.
Debating on buying this but I'm so indecisive lol.
https://www.shopchevyparts.com/performance/2019-silverado-1500-air-intake-kit-performance-cold-air-53l-engine/84789802-p-92300615.html
Either that or maybe add the fog lights to the truck.  But Ehh, not sure any of these two mods will make much of a difference.
https://www.shopchevyparts.com/electronics/2019-silverado-1500-led-front-fog-light-package-models-without-task-lighting-set-lights/84125494-p-92300703.html
What do you think?
I agree! They don't claim HP numbers, but what they do claim is air flow and air restriction. They "minimize air restriction and flows 51.69% better than stock."
The GM's air intake is rated at 13% air restriction.  So in theory the S & B is 4 times better than the Gm intake. So it probably makes 8 to 10 HP compared to GM's 2 that they claim if you take it from the performance package.
When I put it on my 2018, I could truly feel the difference, and the sound was amazing.
I can't wait for mine on my 2019, and the price is fantastic for the product you are getting. I don't believe even the RotoFab flows that much air and the S & B is $170 cheaper!!  You won't be disappointed.
Yep, I already pulled the trigger on this lol.  S&B CAI comes on monday.  Wohoo!!
Ops! The Holland tunnel would flow more air yet on a test bench as a stand alone. Thing is, the motor doesn't. If this were not so then 4X more air = 4X more power not 8 hp at peak rpm at WOT. A place you visit about what? Once a year? The OEM is a CAI. On the road it will be within 2 or 3 F of ambient. In town it doesn't matter. What you buy with a CAI is noise. If you like noise then great. There are cheaper ways to get noise than a CAI.
For what it’s worth, I saw two different people on the FB group complain about loss of throttle response with the S&B intake. Safe to assume it’s pulling timing with the stock tune, but what they feel may just be perceived.
What isn’t just perceived is the “check engine air filter” message people get in the DIC with these “open” type intakes.
Well I already have an exhaust, and the noise does sound sweet.  Next up, turbo whistle in the exhaust! lol JK
  • Haha 1
I've read and seen lots of videos that say the throttle response is improved with the S&B.  Also may just be placebo effect but ehh either way.  I could always change it out if I'm not happy with it.
Not really worried about any messages in the DIC, I know it's recommended to turn off the air filter life indicator as it won't be accurate.  Could always drop a chunk of change and get a tune :D.
All you have to do is turn off the air filter life indicator. Very simple. The S&B has a plexi-glass cover so you can see the filter condition without having to open the whole thing up.
Y’all are gonna make me get one of these S&B CAIs here soon lol
Next up on the list will be the JLT Oil Catch can and the S&B CAI
Can anyone elaborate on the difference between the difference between S&B Cold Air Intake with Dry Extendable Filter VS. the one with the oiled cotton filter?
I went with the dry one, IMO it really doesn't matter that much.  Oiled filter technically filters more but is more maintenance I think.  I've never had an oiled one so I figured dry would be the way to go with me.
After looking more into this thread, I don’t want any error messages to pop up about “check air filter” etc. also I want the air filter indicator to be accurate. Are there any direct swap CAIs that don’t affect any of these electronics?
I also have the dry one. The oiled ones can mess up the mass air flow sensor if not oiled properly.
@Grumpy Bear......that's your opinion, but I have had one of these and it makes a huge difference. Do you want to know how? Well, after racing my stepdads ecoboost, I gained a half a truck length, so you can take your ambient temperatures along with your stock air intake and grab a bowl of porridge and maybe you will be HappyBear!
Good Day!!
Also with these CAI, you must unplug the battery for 2 1/2 hours and then shut off the filter light on dash, and you won't have any problems!
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
