Got my vin today for 2020 Silverado (XQPRVD order number) built last week I believe. My salesman says everything is different on the shipping side (they no longer ship by rail) so he can't give me an idea on approximate time my truck should be at dealership. Any idea how they are shipping them from factory now? I know they were shipped on rail to closest rail yards and then picked up by transport semis. Event codes use to tell where it was at every stage, maybe they don't use those anymore?
Edited by RedHot6.2
Got my vin today for 2020 Silverado built last week I believe. My salesman says everything is different on the shipping side (they no longer ship by rail) so he can't give me an idea on approximate time truck should be at dealership. Any idea how they are shipping them from factory now? Event codes use to tell where it was at every stage, maybe they don't use those anymore?
They always came in on a semi when i worked at a dealer like 7 years ago
Sent from my SM-G973U using Tapatalk
Thanks. I figured they still used vehicle transport trucks but those are after they've traveled by train from the factory to a destination where they are put on transport trucks for the last leg of trip.
My 2020 which was built in December was shipped by rail to Kansas City and then by truck to Nebraska. I doubt that the Mexico built units are trucked out of Mexico unless they are not going very far.
Just got vin today and asked about event code. Salesman said "since their shipping has changed, everything is different, trucks no longer using rail system".
Edited by RedHot6.2
They ship via rail to a VDC. Then they are trucked from there. As far as timing goes,
It’s up in the air. Once they are at the VDC it’s all over the place.
Source: I am a Sales Manager at a Buick/GMC dealer.
Edit: If you are close enough to the plant, the dealer can pick them up at the holding yard, under certain circumstances.
see semis dropping them off here in so cal.....no matter the brand all come by truck, unless dealer trade nearby they just drive them
They're picked up at the rail yard by the truck. The vast majority of Silverados/Sierras will spend time on a rail car.
Thanks. Guess my salesman doesn't know what he is talking about.
for sure that's a given, thought he ment how are they actually delivered at dealership.....
  • RedHot6.2 changed the title to Silverados not sent by rail from factory?
2500/3500'a are built in Flint. They are still being sent to New Boston (Detroit) to ship out by rail across the country. I don't see why 1500's would not also be rail headed? I think your dealer is mis informed.
My truck was made in Mexico. At this moment it is on a boat somewhere in the Atlantic Ocean heading to Davisville, Rhode Island. Then a car carrier ride to the dealership. I think. It’s been on a boat for 3 weeks.
I'll second this...I work right around the corner from Flint Assembly and drive by it every day. The are def shipping via Rail from there as well as some via truck transport.
Pretty sure its rail to a yard, then picked up by Cassens, Jack Cooper, etc. then delivered to the dealer.  You can hit up Google Maps and see the rail loading point at the plant.  https://www.google.com/maps/place/Flint,+MI/@42.982351,-83.7264837,583m/data=!3m1!1e3!4m5!3m4!1s0x882378fba5977317:0xc1853a098e33686b!8m2!3d43.0125274!4d-83.6874562?hl=en&authuser=0
The only exception that I can think of is Corvette, as I think those go by truck right from the plant to dealers via Jack Cooper.
Edited by newdude
Thanks. Mine is a 1500 crew cab so I'm assuming it was built in Mexico too. Did you get that info from your dealer? I may have to check with someone higher up at my dealership, getting a straight answer from my salesman is proving difficult. ?
Edited by RedHot6.2
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
