I have a 2015 GMC Yukon Denali @ 36k miles.  It was Magnetic Ride Control.  About 6 months ago dealer indicated my right front strut was leaking and I found out quickly how much it is to replace one!
Driving the truck now on highway it has felt like possibly the shocks are not working so I took a look at the rears and noticed some moisture around one and debris on another.  Not sure if this is normal or indicative of a failure.
Anyone had one fail and see what it looks like?
https://imgur.com/a/SX5uu8f
Both rear shocks found shot, air bags not holding air, nothing to be seen; however, when truck was not level the rear shock air compressor would work continuously trying to fill the air bags to level the truck, until the truck was shut off.  Had the truck been left on would have eventually burned out the compressor.  Have a garage/mechanic you trust check them out (unless still under warranty).  If interested I can tell you where I found OME replacements at the lowest, but still expensive, price.  Good luck.
@Russ Swift - Crazy.  I don't have any issues like that.  My drive is just a little rougher than expected lately.  I did find some OEM replacements for the rear and they seem economical compared to dealer price $310ish.
I'm just curious if a non dealer can properly diagnose them since they're so complicated.  Dealer charged me $900 for the failed front one.  I may have them check the rears next time I go in although in these times you always worry they're hurting for business and may recommend it a bit earlier than necessary.
High Guys, I feel your pain!  I have had ongoing issues with my MagRide in my 2015 Yukon Denali - BUT WAIT!  I have good news!  My ride is now (last 2 weeks) SMOOTH as driving it off the lot!  Here is a very brief summary of what I did:
  1. Had 2 bad shocks, 1 up front and 1 in the back = Replaced all 4x
    1. Result:  Ride was better but NOT smooth NOT what it should be
  2. Took it to several stealerships - No one could "find any issues"
  3. Bough this reader / writer: Autel AP200 (TH200) <-- Link to Amazon Best $70 I have spent on the truck
    1. Read and Cleared ALL Codes (Especially ride control)  Note:  I did NOT have any "check engine" codes or lights
    2. Result:  SMOOTH SMOOTH Ride - what it should be after having new shock all around
I am very very happy with the ride in the Yukon again.
Note:  No matter how may times I asked stealerships to check ride control modules and any low level/deep codes = They all  failed, they said they could not find any issues
I just replaced all four shocks on my wife's 2016 Yukon Denali XL and it is still riding like crap.  The back shocks were toast and one of the front shocks had fluid leaking out.  Yes ride did improve but not to what I expected.  My Jeep rides better than my Denali and that just is not right.
I was feeling the same way until I cleared all the codes. I recommend either having the dealer clear EVERYTHING or doing it yourself
Unfortunately I did not find any codes to clear.  Anyone know if this looks normal in regards to ride height sensors?
I imagine the ride height is whatever it is. What matters is that it adjusts tot he up and down while you drive so the shock signal is sent accordingly
I did the trim and no dice yet but I'm starting to think it may be a tire or balance issue at this point. I'll stop spamming here until I find a resolution (if I do). I could just be expecting too much out of the truck or have terrible roads near me. Seems to happen more at 60mph or so than 30-40.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
    • I keep getting the above error message on my 25 Sierra.  If I reset the infotainment unit (via the phone hang up button) it will work again for a day or 2.   But I dont want to do have to reset  all the time. Works fine in my 2023 Corvette. On both vehicles I connect wirelessly.   I have a Google Pixel 10 Pro XL, phone is up to date.  Any Ideas.  See attached
