On 7/25/2020 at 9:13 AM, lebag335 said:
I’m in Texas too. How does the state sticker affect the windshield tint. I’m concerned about removing old sticker and damaging the tint?
We use a clear vinyl static rectangle and stick the registration sticker to that then stick it to the windshield.  That way you can pull it off without damaging the film. We only do 80% clear UV film.
update, got 30 ceramic on front doors and 50 on windshield with no issues so far.
Update. I had my windshield tinted with Air80. Ended up with some bubbling around the rear view mirror so they redid it. No issues with the electronics either time. It definitely makes a big difference with the heat inside the truck.
Be careful tinting your windows!! Some will say nothing below the "AS1" Line, some say 4 inches some say 6 inches etc... What may be legal in your state may not be legal in another. By that I mean if it's legal in your state and you drive into another state "They CAN get you!!! Most states do not allow much other than factory tint on driver and passenger side windows but its OK to tint back and rear side windows completely black. I know of many folks whos tint had to be removed "ON-SITE" before being allowed to continue!!
This probably isn’t true.. if this were the case, you could get pulled over and ticketed for not having a front plate in states that require 2 plates.
By the way I am a former officer on a state level. All operators of motor vehicles must comply with vehicle requirements (Private or Commercial) in the state in which they are operating a vehicle. Plates and Window tint are separate issues!
This is totally true. If the police officer wants to enforce his state law on window tint. He has every right too. Most don’t because they see you have a different license plate. But they can. My sister lived in Nebraska. Drove over to Iowa and got pulled over for her tint because there front window laws are different.
You are correct when you say "Most Don't" BUT they can!!
On 7/21/2020 at 6:08 PM, birdsdawordxxx said:
Has anyone ran into any problems with getting their windshield tinted.
Cause being able to actually see is way over-rated.
  • 2 years later...
Has anyone actually had any issues?
I just picked up a 2023 LTZ and my tint shop who I've used for 8 years just told me this. I have to sign a waiver to get Air 80 put on my front windshield (they use Llumar.) He said they'd shove towels/etc down in there to be safe, but I will need to sign the waiver.
I have 35% ceramic 3M tint on the whole windshield of my 22 AT4. It has been like this for 6 months and I have had zero issues with visibility or the electronics in the truck. I had the same on my 21 AT4, also with zero issues. I have used the same tint guy for 10+ years and he does great work.
Zero issues.  Have the Air 70 on the windshield and 15% on the front, rear and sunroof.  I can see the HUD just fine.
As far as the inspection sticker, I ended up buying static cling stickers.  I cut it out a little bigger than the inspection sticker and then stuck it to the windshield.  Before attaching the inspection sticker to the static cling sticker, I put the adhesive side on a t-shirt so that it picks up lint.  After doing this a few times, I pressed it to the static cling sticker that is on the windshield.  Now I can peel it off with no issues and I don't have to use a scraper.  I also attached the toll stickers the same way.
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 458 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
