Text messages
14 hours ago, Porterhouse said:
My truck will read the texts out load and ask me if I want to reply...maybe it has to do with phones your using?
Sent from my Pixel 3 XL using Tapatalk
Early builds had the messaging app, I have it as well, but Gm stopped putting the app in the trucks at around 12/18.
Works perfectly in my truck (May 2019 build). It worked when I got the truck then it did an update and I lost it. I had to call gm (special number) to have them put it back.
Ryan B.
Yeah, I had the same issue, I had to call to have them re-activate it, I was told they stopped putting the App in the truck by their representative, I guess either he told me the wrong date or I heard the wrong date but either way I know they stopped putting the App in the trucks.
I think it was on mine too but was gone from an update before I got to try it.  What number do you call to have it reinstalled?
That was a nice feature on my jeep i miss it on my 2020 sierra. it works with android auto, but i rarely have that running.
I figured they got rid of it because too many guys getting busted when girlfriend texts and wifey is in the passenger seat.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
