P0106 and P0300 with 197 miles on the odometer.  Guess we'll find out what happened Monday.
Was it able to crank and start at all?  I think I remember some on here with some crazy error codes like that due to extremely low or discharged battery.
I've got a 2020 6.2 Sierra as well.  These trucks got some crazy issues.
It went from idling normally while I unloaded the bed at the dump to suddenly stumbling and ultimately stalling.  If I held the accelerator down and cranked I could get it to start.  As long as I kept my foot down and the rpms around 2k it would run but it was shaking bad and that's when the check engine light started flashing.  Let my foot off... Stall.
Had my daughter bring some isoheet just in case it was water in the fuel.  Shook the truck to mix then restarted with same results.
After the tow same thing.
Got a call from the dealership.  Broken valve spring.  Awaiting words.
Edited by calgator73
details
It scares me how many engine and parking brake issues these 2019 and 2020 trucks have.
Makes me wonder what the actual percentage of problems compared to total number of trucks produced....Or is it just the fact that we see them more frequently because we come to these forums.
That last part is probably on point.
So the outcome:
Engine fixed.
Warranty extended to 6y/100k
All of my accessories installed free of charge
Cat back
CAI w/cal
Gmc Puddle lamps
Console vault
Illuminated blacked out front emblem
Blacked out rear emblem
  • Like 4
39 minutes ago, Shiva said:
Sounds like your dealership did right by you.  I used to live in Northern VA and there were a couple of good ones down there.
I have to say.  Suttle Motors is not a bad place to do business.
What is your build date?  Take a look at this post...
I have a Sierra 6.2 Build date of 8/20 already with a leaking rear window issue that hasn't been resolved yet...
Took delivery of my at4 last week, 316 miles in and the exact same issue... Broken valve spring.  They towed it in yesterday, fixed it and returned it today.  How did you go about getting them to extend the warranty, etc?
Same build date 8/20.  Thanks for the info.
I didn't state warranty piece accurately.  It was a component coverage letter.
gmc engine failure.pdf
Absolutely correct, they started having crazy issues going full electrical and today still carry that gene but with even more crap in them.
