18 hours ago, EX-F150 said:
I have to throw a recommendation for Truck Alterations and Lomax.   Truck Alterations had the best price and Lomax offers great follow service.   I just received my Lomax yesterday.  When I opened the box, I saw that one of the mounting rails had some scratches on it.   I emailed Lomax this morning and within an hour, I received shipping notice for a new mounting rail.   You can't beat that for customer service.  Nice to see a company stand behind their product and take care of their customers.
I just put my Lomax on last week. Its a great cover and Truck Alterations has an awesome price!!  Once I realized that the Lomax cover was made by ACI it was a no brainer for me. They are a great company. I have one of their Snowsport snow plows and their customer service is top notch. That and the price from TA sold me on it!
I ordered the Lomax TriFold from Truck Alterations Tuesday afternoon at about 4:00.  I went home for lunch today and it was being delivered at about 1:00 today (Thursday).  The price was still at $675 shipped with no sales tax.  Luke was awesome to work with.  Now I get to install it tonight!
Truxedo for me.  Low pro on 3 previous trucks and X15 on the new one.   X15 is just like a LoPro with better material.
Did you find it hard to latch the cover with the tailgate closed? I installed mine today and I’m having issues latching it with the tailgate closed. I have to stand on the bumper and it’s still a pain
Installed my Lomax from Truck alterations last night.
Install was easy and straightforward.
Rained moderately hard here for a while today. A little leaking toward the front, but it went straight down the drain holes.
A little extra weatherstrip would probably solve it.
It's really low profile, and so far I'm very pleased. (and Luke was great)
I wanted something that was moderately secure, yet could be removed quickly if I wanted full use of my bed.
This seems to fit the bill perfectly.
I have to give a shout out to Luke at Truck Alterations. I emailed him yesterday during the holiday looking for a black urethane Lomax.
Not only was he responsive, he also had the best price. $710 shipped. The matte model is still $675.
Thanks GM-trucks for passing along the info!
Revolver X2 or X4. Had the X2 on my 15 for 5 years and not one issue, didnt leak at all. Just put the newer X4 on my 21, same quality.
Edited by GMC207
I have the Retrax OneMX and have been really impressed with it. I like that it locks in any position and after tweaking it a bit ive got it to where my power tailgate still drops without touching it. No Leaks and nice and low pro.
62802550973__D5BC75EF-395F-47BA-BA33-F99376B66AE2.thumb.jpg.0ba07b16b75be8adbfdcf4e49c246245.jpg62387588650__4D39ED6A-DACB-4D6B-BFF1-7FE58FE98F5E.thumb.jpg.c3168f219a88aaddb614f536661bbd59.jpg
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 1,769 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
