On 9/17/2020 at 7:10 PM, icemanRC said:
I have a 2020 GMC Sierra SLT. One of the factory options is adding the bed view camera for $250. Since mine did not come with this, I wondered if it would be possible to add it? Being that it’s only a $250 factory option, I figured it can’t that difficult to do. Has anyone done this or have any knowledge of this?
Iceman, if you happen to find an answer to adding the bed view camera, please let us know, I too am wanting to attempt to get this installed.
I want an answer to this as well.  I would like to add it to my AT4 to aid in 5th wheel hookup.  Not interested in the mirror.  Just the bed view camera.
-Eli
On 9/20/2020 at 10:34 AM, icemanRC said:
That’s not true, at all. I was looking at two identical trucks. One had the extra bed view camera, one didn’t. The difference in price was $250
I priced up a Sierra SLT on the GMC build and price site and to add the bed camera I had to first have the Driver alert package, convenience package, premium packages to add that $250 camera.
Edited by Greyhound6.2
Yes, but all of that is included in the Premium Plus package, which I have.
On 9/20/2020 at 7:06 AM, icemanRC said:
I would have thought it would be a simple plug and play. I haven’t removed the lamp assembly and looked, but I figured that there’s already a wiring harness there. I couldn’t see it being anything difficult since it’s only a $250 factory option. Cheap options usually mean fast and easy. If it was $1,000 option, I’d believe there was much more to it than just a simple harness plug in.
I guess I will call GMC and see what info I can find out.
Did you ever call or find out anything from the dealer?
  • 2 years later...
Sorry to bring this post back the from grave but interested to know if anyone has done this yet? I just ordered the parts to at least do the live view rear view mirror (DRZ) upgrade. Would be nice to get the bed camera working as well.
Camera review mirror and the bedview camera are separate cameras.
So if you want both you need the assembly with TWO cameras
Yea I ordered the assembly with both cameras Im just not sure where to find the harness or cable that hooks from the bed view camera up to the VCM.
Edited by BrizzlesBowTie23
I purchased the new light with the bed view camera only with wire harness for $175 I plan to install it this week . will update of how it works out
Hate to highjack, but I'm watching closely as well, but I'm looking to add the front camera to a 2023.  I'm thinking whatever gets resolved here just might work for a front camera too?
  • 10 months later...
39 minutes ago, Dennis5.3 said:
thanks but I sold it about a year ago. Only 23,000 miles and had lifter and transmission issues. GM admitted the lifters were bad but said they wouldn’t replace engine until the engine failed. I guess they thought that was quality customer service and thought I would enjoy to continue to stare at a check engine light. This was my first and last GM vehicle.
Edited by icemanRC
  • 8 months later...
@BrizzlesBowTie23 Were you able to figure out and install the rear view camera ?
@djdapper Any luck installing just the bed view camera ?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
