'21 GMC WT, 3500, SRW, Crew, standard, gas,
Payload = 4,044 lbs.
Edited by T.O.
2021 2500 High Country Gas CC SB w/ deluxe, sunroof, snow plow prep, z71 = 3248 lbs of payload available
Edited by M Parr
Add bed / can config
Fwiw, there will be another label on the outside of the doorpost, down at the bottom, that has a bunch more info on it.
My 2021 Sierra Denali HD 3500 SRW Duramax (5th Wheel pkg, Denali Ultimate pkg, Black Diamond pkg, Rear Under-Seat Storage). Curb Weight 8,417 lbs. Payload 3683
My brothers 2021 Sierra Denali HD 3500 DRW Duramax (5th Wheel pkg, Denali Ultimate pkg). Curb Weight 8706 lbs. Payload 5294 lbs.
It makes no sense some of their numbers. Had a friend with a 14 2500 gas lt his payload was 27xx i have a 15 high country gas and my payload is 2680.
On 9/22/2020 at 5:31 PM, Njmurvin said:
Crew cab, standard bed, 4x4, LT 3500 Duramax - 3895 payload.
included goose / fifth package?    Soon I will order...
Yes!  Options include: Duramax, convenience packages 1 and 2, gooseneck/fifth wheel package, Z71 offroad and protection, leather package, hitch package and Autotrac 2-speed transfer case.
Thanks NJmurvin,        What about asissts step?
I had the dealer add the GM chrome tubular steps before I took delivery (and they're very nice).
those duallys have lot more......a gas version prolly 6k plus
for me its payload not towing, at least for now
2021 2wd reg cab dually payload:
gasser 7442 lb
diesel 6523 lb
2021 2wd crew dually payload
gas 6894 lb
diesel 5894 lb
for both:
GVWR 14000 lb
RGAWR 10500 lb
4wd payloads a little less, GVWR and RGAWR are the same, so weight of transfer case, front diff, front drive shaft and half shafts all reduce available payload.
Edited by redwngr
What size of wheel do you currently have?  18 or 20 inch?
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
