I just picked up my AT4 this morning!  I'm coming from an '18 SLT which I put a 2" RC level in the front and sumo springs in the rear.  So stock, my AT4 front sits similar to my '18 up front with the level.  I like this height as I take off the running boards and can step into the truck comfortably.  I hunt and fish so my truck goes offroad, plus I plow my drive with my truck, but the stock front height is just fine for me.  I'm considering leveling the AT4 by lowering the rear 2".  Has anyone done this yet?  What is needed?  I'm guessing there is a block lift in the back that could be removed, but would I also have to change shocks?  Anything else?
I used WULF suspension shackles on my RST. Perfect fit and has 2 holes for 1 or 2" drop and grease zerk fittings. I'm not sure why shackles won't fit the AT4.
There is a 2" block under the leaf springs so that's all that is needed to take off to make it drop 2".  The shocks should be ok but I'm not certain on that.  You might need to replace them with something else for a stock height truck.  Is this a 1500 or 2500?
What's the point of buying an AT4 when if you're just going to lower the rear and have it sit the same height as a Z71/X31?  Could have saved a bit of money by not getting it when the Z71/X31 since all you get is a 2" lift.  Yea you get all those camera's a HUD but that's stuff you can get in a higher trim, non AT4.
Removing the rear levels the truck.  A non AT4/TB is 2 inches lower in the front.
Plus, unless I'm missing something, the HUD is only available in the AT4/Denali or High Country.
Im sure. That's why I said higher level trim.
My ZL1 has it standard and I've used it a handful of times but since I wear polarized lenses, I can't see it.
Ive used it on the track once and never paid attention to it. Used it on the highway a few times without sunglasses and hardly paid attention to it.
I’m coming from a loaded, leveled SLT and the AT4 was the truck with the equipment I wanted plus I love the looks of them. I wanted less chrome on this one.  If I remove the rear block do I need to replace the shocks with a non AT4 version?
  • 6 months later...
No. Ask yourself why the rear is higher than the front? Answer. So when you are hauling the maximum payload the sticker allows the truck sits......LEVEL! Ergo it is designed that the rear shocks are in mid stroke when the truck is level. 😉
The shocks are longer on the at4. I replaced mine when I removed the block, but only due to the fact that i had king shocks from my old truck that fit perfectly after removing the block. I don't see any way for the stock at4 shocks to hurt anything if left in place, but if the suspension is completely bottomed out, then they may blow out. If they do get damaged, buy new ones that are the correct length for a non at4 pickup. Don't have much to lose.
Side note: If you are concerned about damage from leaving the shocks on, you can simply leave the bump stop extension bolted on to the axle so the bump stop will limit the travel instead of the shock being the limiting factor.
  • 8 months later...
I know this is an old thread, but did you have any vibrations or have to put a shim like the non at4 has, after you removed the blocks?
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
