I got a 2020 Silverado 1500 back in December and I have about 16000 miles on it now.  I gave it a bath the other day and noticed a crap ton of rock chips in front of the rear tires, right where it flares out behind the rear doors.  My pickup is black and fairly noticable and I was wondering if anyone has a remedy to protect that spot.
Find a local place that does aftermarket paint protection film installs.
A company called Xpel sells a product for this as do others, they sell pre-made kits for vehicles but they are pretty expensive.
Having a place just to small sections will cost you less.
Edited by CamGTP
no real remedy except protective film but that is expensive i also have a month old new black truck and i am not happy with the paint i have chips in mine already the paint chips way to easily i have one in front fender and one in front passenger door and back passenger door that look like crap on black they really show up bad because the primer is white i tried to touch up and buff by hand with micro fiber towel and burned through the paint the paint turned a brown color getting door repainted paint is to thin then i got another in back door tried doctor color chip repair it works ok but you can still see chip may get that door repainted also it is a shame for the money we pay for these trucks that the paint is so shitty
Just a tip for touching up stone chips i saw from a YouTube video. Needle and syringe does wonders for precisely touching up stone chips. Much easier than trying to brush it on. You can pretty much just get the paint in the chip area and not the surrounding area and it lays in real nice.
If someone finds a film that works please post here. The 2 places I checked locally won't do it because the film won't mold correctly with the rough                      " protectant "  in front of the rear wheel and leave noticeable bubbles in the film.
I have a 2020 SLT in the Dark Blue and the paint sucks, picks ups chips and scratches if you look at it wrong. I can say I am glad I made them add the protection package to my contract for free, which they are already regretting I am sure since they had had to repair several chips and scratches. The plastic films are nice when they work but you need to be careful it doesn't void your warranty if you have the protection package. My dealership will give you touchup paint that match a better than the stuff I have tried from autoparts stores. The Needle trick works like a charm.
Thank you for all the replies.  Im gonna save up for the black Luverne side step running boards, and replace the factory mud flaps with weather tech's, the factory ones curve in at the bottom but the weather tech flaps stay square.  I have a friend who works at a body shop who will repair the chips, once I get the stuff in, and hopefully the problem fixed.
how can this void your warranty? I see that often on here, is GM trying not to cover things that have nothing to do with this? or are you just saying for the paint you covered?
Sorry for the confusion, the way I read the appearance guard contract pretty much anything you add to the paint can void the appearance warranty. They want you to use the products they give you and to wax/seal the truck at least twice a year, which I normally do anyway. I dislike the car wash and interior protector they give you so I use my normal Chemical Guys. Shhhh don't tell them lol.
Thanks for clarity - I would argue that outside of where you installed the guard would still be the warrantors responsibility, they might try to bully you a bit, but stand your ground....I believe it would be pretty hard for them to show they are not liable where you have not added any aftermarket...
    • As the title suggests, I have an unused General Motors authorization code for a set of bed perimeter lighting lamps that I bought. My truck was built with the option for perimeter lighting, and they worked without programming… So now I just have this code. What is it good for now? Can anyone here use it?
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
