1 hour ago, TNTSilverado said:
I don’t understand why not. They have the resources and small block heritage behind them to seriously Start a performance street truck division and put a huge hinder into Ford and Rams off roaders.  A blown LS7 could easily push 800+ hp and be very reliable.
A buddy of mine just bought 09 Z06 and absolutely loves the 7.0L.
I’d sign on the line the minute it hit showroom floors and I guarantee many others on here would join me.
100% agree with you brother. I think a blown 7.0 would be awesome as I mentioned but they need R&D etc etc. they already have two  6.2 blower motor cars. One with 1.7 blower and the other with 2.7. These motors would be nice in a Silverado. Wider track , more travel , 35s , under body protection , major offroad prowess. Cmon GM give it to us !  Ram already sold out all of their TRXs before they even come out.
  • Thanks 1
8 minutes ago, f8l vnm said:
Here is mine.. Zero time to drive it. Just sits The 7.0 is glorious. And the lightweight made it a phenomenal machine.
Love it. My buddies is Silver. Sweet looking car. He has headers, cam, exhaust, and tune in it currently. Doesn’t know if he wants to supercharge it or not.
Edited by TNTSilverado
I am very leery towards electronic transmissions and I don't see myself shifting it faster especially if doing it by feel. We had a Silver Spur and the GM400 which was obviously connected electronically to the column shifter. As the car got older, the waiting time to feel the click going from "P" to "D" was taking longer and longer. A few times, she'd forget and hit the gas after shifting, causing the car to thrust. Sure, it was smooth shifting it but I preferred the 1972 Kingswood where the shifter of the SAME transmission had that manual, meaty and clunky, feel to it, and I found it much easier as I didn't have to go slow to make sure I picked the right one.
Edited by Wiggums
On 10/20/2020 at 10:17 AM, Jim E said:
If you are getting a basic or low option truck, you wouldnt be getting a large screen anyway.  The large screen would be with the "high end" stereo which includes Nav.
I would like the larger screen as it would give you a larger, easier to view screen when using split screen mode (ie: displaying Nav and Radio).  As it is now, the Nav map is mostly useless in split screen.
Just an option. Cheaper then a new ride:
That looks pretty damn good actually. Amazing how much life it gives the K2 interior. Pretty neat that it also looks it’s stock for the most part.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
