I found a guide to drop the unit and will be digging into this next week.  Has anyone tried pulling this unit apart yet?
My goal?
Adjust the beam closer to my lap instead of the door
Edited by Rob Mugs
Not bright enough to mess with. I bought some LED rock lights, found the hot wire, mounted 2 to bottom of console. WAY BRIGHT. I think 1 would work. They turn on and off with map lights.
Edited by Arboc
spelling
It's sad but I wish the OEM lights had replaceable bulbs.  My 2020 is better than my 2015 was, but still not bright.   In all of my wife's Hondas' I've pulled the 194 bulbs and replace them with a flat panel of 18 LEDs.  It's like daylight the moment you unlock the doors.    I'd love to do it to my truck, but I might just install some lights in the foot well area.
14 hours ago, Javier121 said:
Where did you tap light to make them work in conjuction with dome lights what wire on that top light is best to tap into?
Here's a thread that might give you some additional information.
Search for Interior lighting on this forum. It will involve a lot of reading but it will be worth it. You can install Oznium LEDs up in the overhead console.
Copy. Bought two of them but got apprehensive if I wanted to see two yellow eyeballs looking at me when they aren’t on…………
Seriously considering another light assembly about the middle but not wanting a hole in the headliner for the wiring is stopping me on that one. May see if I can add an LED light just rearward of the console. Like right next to it….
Went ahead with two in the upper console….
BEFORE
IMG_0605.jpeg.c6993f25b62a8222788227031a2554e5.jpegIMG_0603.jpeg.1046d281cd5a314cbbd1c4fe1344a3dd.jpeg
Nothing new but two LEDS really help…
Edited by DHBWA
BEFORE
how did you add them?
