I am about to buy a new 2021 Sierra next week. I will be going from NC to Dallas to pick it up and then drive back home. With the issues I have read about the fuse block bolts I want to be able to fix it myself before heading back for 1000 miles. What size are these bolts and do I need a short extension? I would really hate to be stuck in the middle of nowhere.
I'm with Jav_eee on this. What issue are you talking about? A few weeks after picking up my 2020 I moved from southeast Virginia to southwest California. I drove the entire way, and had zero problems.
It is either a 7mm or 9/32.  I used the 7mm.  No extension needed.  Can't hurt to check them.  Takes 2 minutes.
Thanks! I plan on checking that before I leave the lot.
What is the fuse block bolt issue? I have a 19 and I’m not aware of this...
There have been numerous posts about the loose bolts in the underhood fuse box causing crank but no start, cel popping up and other warnings. There is even a TSB on it. I just couldn't find the size of the bolts.
Rusty relax and enjoy your drive home, not only will you be covered by GMC's bumper to bumper warranty, but you will have roadside assistance too, I would be more worried about distracted drivers causing an accident or a stone throw chipping your brand new paint, just stay well back from tractor/trailers on the freeway, especially empty flat-beds that are notorious for flying debris.
Edited by garagerog
Interesting. This is the first time I’ve heard of it. Guess I’ll check mine for funsies!
I am trying to be proactive not reactive especially hundreds of miles from home in the early morning hours when no dealers are open.
Usually, by the time they create a bulletin for something like that they have identified and corrected whatever caused the problem during assembly.
So on later built vehicles...
While I totally agree with you, I don't want to take a chance. Like a saying goes, an ounce of prevention is worth a pound of cure. Better safe than sorry.
Bulletin says only 19 and 20 models and not 2021, so don't worry about it.
Me too.....never heard of it.
Guess I'll check the bolts on my 2020 RST just in case.
I've been accused of having a few screws loose, but that's another story. ?
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,284 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
