^ This as my rear fenders already got hammered stock on gravel roads. Plus I don't want to have anything that could potentially cause catastrophic issues when towing/hauling heavy or being used off road, spacers don't have the best track record for reliability. I guess if it doesn't do much truck stuff it is fine. Not to mention I kind of am a fan of my wheel bearings and would rather not put them under any extra strain as replacing them isn't a fun task. To each their own, stuff like this is why I won't buy a used truck.
Tyler
Im not here to change or challenge anyone knowledge. I just want to share some ideas and pictures. I have used wheel spacers on my Jeeps for over 14 years never had a problem. I have rock crawled, driven 70 mhp thought the desert and bearing, wheel and wheel spaces been fine. Just make sure the spacer are made with T 6061 aluminum.  So far the mad flap been doing a good job of protecting the side of my truck. Here are so pictures of my Jeep with 2.5 inch spacer.
1 hour ago, redwngr said:
Changing the steering geometry for a different 'look'?
Steering geometry I haven't notice a different. If there is, its to small to notice.
Wow tough crowd, personally I like the “look” of them and have had them on all my trucks and knock on wood never had an issue. I’ve had them with 33’s to 40” tires and only have 1 issue which was my fault as I didn’t loctite the lugs.
what’s more idiotic is guys cutting fender and mudflaps to fit a 35” on a damn leveling kit! Meaning don’t troll and be a dbag, guy was just showing his truck with spacers.
  • Like 4
Love the look! Did they fit okay or did you have to cut the studs?
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
    • I get it, Bad Bunny is huge but not everyone knows him The generational gap in music taste is real At least the show will be lively
