I would put them on my AT4 if they were offered with power fold and a gloss black cap.  Seems you can only get the uplevel mirrors as a FACTORY option.
-Eli
-Eli
Or a little bit of searching and a couple of wrenches
My GMC X31 came from the factory with the tow mirrors. Cannot decide if I like them or not. I don’t tow anything major. Just a small bass boat and utility trailer. I feel like they look a little oversized for a 1500.
They are. I completely agree with that. My truck came with the tow mirrors from the factory.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
