37 minutes ago, Tjeli said:
Ask them to show you actual proof that this happened.  I still don't see how its possible with the intake design on our trucks.  I am leaning towards a mistake they made on your last oil change and they are trying to cover it up.
How would this explain the water in the intake?
The actually showed you the water in the intake?
Yeah once the dealer had it and looked at it
How's the gasket at the air box side of the air intake tube that comes from behind the grill? I installed the GM Performance intake on my truck and found that to be very loose for a factory install. Lots of wiggle room on that end of the tube.
There is still no possible way this could happen driving through 3" of water.  Not even if you were going 100 MPH.
-Eli
Has OP gone ahead and filed the claim with his insurance, or is it sitting in the back lot of the dealer racking up storage fees?
I have filed a claim with my insurance. Especially because GM has not got back to me with any definitive answer on anything.
Not sure the dealer has gone through it so I’m sure everything is loose now
-Eli
My question from day 1. How could this happen and no one at the dealer or GM has given me a definitive answer. New motor cost about 10k out the door they can simply replace this at cost and cut that down to half but they refuse to help in any way. Well they haven’t refused they just don’t respond to me
Gus
Go walk into the place and say WTF dont you people return phone calls?
That'll raise a few eyebrows and probably get you some action. No way in hell I would put up with b.s. like that .
Sent from my Pixel 3 using Tapatalk
40 minutes ago, dieselfan1 said:
Gus
Hahaha, the problem is GM isn’t responding and they’re in Detroit. I’m in California (unfortunately) but I agree this is some BS.
I'd still go into the dealer where your dead truck is at and still say WTF. Make them call Detroit.
Life is too short to have to spend time dicking around like this.
For sure, I just had it towed to another dealer yesterday because the last dealer was useless. I’ll give it a day or 2 max to see what the response is here. This mew spot seems like they have it together but who knows.
So, after today I do have to question this situation, even though I posted a similar story earlier about how I can see it happening because it happened to me. I took my car to the wash today. It's one of those do it yourself places with the brush and high pressure sprayer. I decided to clean under the hood this time since it was dirty from 9,000 miles of driving. I did the engine degreaser, high pressure spray, low pressure spot free rinse, etc. I have the GM Performance intake. You betcha a ton of water went down that tube before the radiator. After I finished washing my truck I got into it and it fired right up. I drove it out of the bay with no difficulty at all. I drove her home, which included surface and interstate driving, and going up and down hills. When I got home I backed her into the driveway. Since then I took my son to the batting cages, took him to dinner, went home, realized my wife didn't feed our 2 kids and it was already 8pm so I got back into the truck, went and got food, and drove it back home. Several engine cycles, and no issues with water in the engine. Based on post #1, either the water was 4 feet high, or something else happened to the engine. I wonder if we're looking at a broken valve spring that resulted in engine failure? What's the build date on the truck? Truck was built in March, so I don't think that's the issue. Does it rain hard enough to get 4 feet of water in a parking lot in Los Angeles? I doubt it. It's not Norfolk, VA.
I agree with @Transient here because I did the same thing today with my High Country. Washed it in a heated bay with high pressure washer. We have had a blizzard past 2 days and I wanted to get all the grime, salt, and chemical $hit off my truck.  Took me an hour and half to wash and dry it.  Truck took a ton of water in on the front end because it was covered with “grime” from driving on interstate. Truck started up just fine. There has to be something else going on with this issue. Plus, with all those videos I posted earlier in the thread.  These Trailboss’s have been tortured by GM themselves along with all kinds of car magazine publishers. I can’t see how OPs truck did what it did.  There is an underlying problem. Hopefully it get taken care of.
Edited by TNTSilverado
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
