33 minutes ago, Car Dude said:
So if the rings are not installed the result would be a 2" drop or so?
So what he did was that he installed bilstein shocks that was meant for 07-14 GM trucks. Based on the specs of what he installed and what was meant for our trucks, the strut for the older models is shorter, even though placing the snap ring at the highest setting lowered his truck. So if you were to use that same strut and place it on the stock setting, it would even be lower. On bilstein struts, you need to use the snap ring in order to install the coil.
Bob it sounds like you need to be the Guinea pig and tell us how it goes lol. I have been wanting to lower the front of mine about 1.5" since before I bought it late 2018. I also heard the bell techs did not ride all that great so I never tried them. I dont want to go to low in the front because of the limited options for the rear without doing a flip kit and a c notch.
Bob ? If the belltech struts are still produced like they were few years back then I believe the ride quality will be worse than stock. Bilsteins are the only aftermarket struts that Ive read nothing but good reviews. Before doing this I would have to get both struts and do some comparison to see if the mounts are the same, from pictures they do.
Owners running 24s, what size tire are you guys running? Im currently on 295/35 but getting thoughts of swapping them out, from different angles they kinda look small on this big body truck. I previously had 295/40 on different set of wheels and liked how they fill the gap but swapped them out after lowering the truck cuz they rubbed badly on dips and couldnt make full turns. Now im debating if I should go with a 285/40 or 305/35 to fill the gap a bit.
285/40 or 285/35 might give you what you are looking for, have you done a size comparison?
295 or 305 are the common go to. 285 would provide a bit of stretch to help with rubbing.
I do not own 24s but just trying to help out
I'm still on stock 20's for now. I would go with the 295/40 if you're staying with the 3/5 drop. It basically gives you the look of a 4/6, wheel well gap wise. 295/35 seems to be the go to size for 4/6 drops. The 295/40 may still rub here and there but it's worth it for the look you want. The only bummer is there isn't much for tire options in a 295/40.
I had a 295/40 Atturo AZ800 on my 2019 Ram with a 3/5 and they were decent for the price. They did rub the top of the fenders on big dips in the road and the tire would hit the frame when turning full cut as well. I think that was more of a wheel offset issue though.73e4048a45a7c01cb7f4d7fc0f2ecdcf.jpg
Sent from my SM-N970U using Tapatalk
What rims are those?  They’re nice!
I don’t have 24’s, but I was told by my installer to don’t go with 305’s because they’ll rub.
I’m in the process of buying 24’s.  I think it all depends on the wheels backspacing if they’ll fit without rubbing.
24x10 DUB Skillz. My plan was to powdercoat these black and use on the Silverado. Unfortunately they don't clear the fluid crossover on the front caliper. Sucks cause they were pretty cheap.
285/35/24 4/6 DROP
Well, since I started this thread, I thought I should give an update on my suspension results and satisfaction. Currently, I have the 2" Maxtrac drop spindles, Maxtrac 4" rear flip kit and Belltech Street Performance shocks all the way around and the front struts are set at the OEM ride height. If I had known ahead of time I would not have used the drop spindles and just lowered the front with the adjustable struts. Reason being is that I am experiencing the front struts fully extending when I hit drops in the road surface causing the front of my truck to dive sharply. Also I am getting some rubbing when I turn lock to lock with the factory wheels. In the rear, the truck is riding super stiff and is causing my truck to dart around the highway because I think the truck is bouncing off of the tire pressure before the shocks react. I have added 2 degree shims to help cure vibration and they didn't completely work. I probably need to go with 6 degree shims, but I haven't gotten around to it. Also, I use my truck as a truck and haul stuff and have hit the bump stops both loaded and unloaded (factory bump stop brackets removed and no C-notch).
So, as much as I love the way the truck looks, I have decided to pull the drop kit off and raise the truck back up. I don't want to go back with the factory shocks so I was thinking about the Billstein 5100s or the 4600s and a 2" drop shackle in the back. Does anyone have any experience with those shocks/struts? By the way, anyone interested in buying a drop kit?!
The beauty of dropped spindles is they have zero effect on travel and little on alignment while maintaining factory half shaft angles. If you topping out that is a dampening issue IF the spring rate has the damper at near mid stroke. Spindles nothing to do with the dampening.
Out back you have to have the room for compression to use the compression. It its skipping about again wrong dampening.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 914 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
