I currently have a 2020 Sierra crew standard bed with the 24 gallon tank and loathe it. I drive roughly 40k a year
ordering a 2021 at4 crew standard bed
has anyone had any luck getting the 28 gallon installed in these crew cab standard bed trucks
thanks
I have a 20 and if anyone comes out with a replacement oversize tank i would be interested mine guzzles the gas when I tow and so far 75% of my miles are towing.
I'm towing with the 24 gal tank as well and is sticks.
Luckily the trailer has a 40gallon fuel tank so I'm not stranded but man 24 gal is really small for a full size.
Have you guys crawled under your truck and noticed the huge irk space in front of the gas tank? Maybe a transfer tank can be mounted there? How To pump the fuel from one tank to another would be the question. I think some of the largest toy haulers may have this feature, so it might be worth looking into???
Bob, what part of the country are you in?  I’m going to pull the 28 gal tank off my long bed soon. I’m down in Houston TX.
My 2020 AT4 has 24  gallon tank and it sucks for towing!  Have spoken with both Tranfer Flow and Titan - neither have any plans to make a "replacement" tank - reason is the fuel tank is not part of the "emission" certification, so it can't be modified without impacting the emmission system.
As far as a transfer tank goes - that is my plan - either in bed or something underneath.  Lots of fuel pumps available in the boat industry that fit perfectly for this.  Plan to put a new fitting in the fuel fill line and do a Y that will allow fuel to flow from the "extra" tank into the main tank.  If I go with the bed tank - will be 40 gallon tank - so that allows for a lot more range.
When you say that you spoke with Titan was in regards to a larger gas or diesel tank?  When chatted with their support they said they were working on for the 3.0 duramax.
Only for gas - I know they have larger tanks for HD''s (2500/3500) and a replacement tank option.  Be nice if they did a larger one for 3.0 - never thought to ask about that, as maybe could use that tank for gas as well?
Wait what! Spill the deets! Any idea on size and timeframe??
Edited by Duramax3oh
They wouldn’t give me any details other than they were working on a larger tank and agreed that the 24 gallon tank was too small.
Coming from an 04 Avalanche 8.1L 2500 with a 37 gallon tank to a 2019 Silverado 6.2L with a 24 gallon tank just has me baffled and confused.  Similar gas mileage on highway.  Used to go weeks without needing gas...now need gas every week.  Subscribing.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
