I've been debating on selling my Pulsar, but only because I want the tuner option.  I figure if I sell it for 300, itd be valuable enough to anybody that needs those options.  It does do what it says it will do, and they do have an afm/dfm dongle I believe as an alternative.
What tuner option are you thinking of going with?. I didn't think they unlocked a tuner for 2021 6.2 yet? Will the tuner your thinking of shut off DFM to? Thank you for any info.
Edited by Liquid Plumber AT4
  • 5 months later...
Oddly I have that same issue mentioned about the driver side blind spot light staying on.
I also have an engine code that have not scanned yet but keeps returning as well as my remote start does not work!
I like the features of the module for the auto stop disable as well as the throttle sensitivity but I’m not keeping it if I’m going to have these and who knows what other issues later on.
I have a 2019 silverado high country with the 6.2 . I am having problems with the pulsar lt. It causes my truck to go haywire. The first one cause the esc and check engine light to come on. So I got a new one sent cause I have a warranty.  The second one cause my check engine light,  tc, loss of engine power 4wd and some more . Is anyone had this and what is the fix for i?
I have a 2019 AT4 6.2 10 speed with Pulsar LT and have not had any really issues. I did have a couple weird warning lights at first but have not had any issues for almost a year now. I do plan to buy the OBDII to USB cable so I can keep the Pulsar updated at some point here just wish it was included with the price these cost.
Did you check that none of the pins were bent in the harness?
Hi, have you sold t your Pulsar LT yet? I am interested if you still have it and not damaged….
thanks….
thanks….
Waiting for an opportunity to be without my truck for 3 days.  Need to send my ECU in.
I have read everyone's comments about the Pulsar LT, I have a 2020 Denali 6.2L and had it installed in my vehicle for a year but I recently removed it due to the following issues. I went to lunch one day from work, less than 3 miles and on the way back the AC quit working, the DIC indicated Service ESC, Service 4WD, Service rack in pinion steering. Based on the info I read on line, I let the truck sit for an hour and went back and started the truck and the AC was back on line but the trouble codes remain. I used the Pulsar LT feature to clear the codes and the truck went back to normal. Simple glitch I guess. Fast forward two months later, driving back from Kentucky and North Carolina, over 6 hundred miles, coming into Alabama cruising 82mph and once again, AC went out, Service ESC, Service Transmission, etc., same issues. I had to pull into the rest stop 6 miles later and pulled the negative battery terminal and let it sit for 20 minutes while I stretched my legs and ate a snack, some what embarrassed with having the F150s, Tundras, and Dodges go by looking at my GMs flagship Denali with the hood up. After reinstalling the negative battery terminal, the vehicle was back to normal. For the comment about the auto side steps, anytime you pull the battery, the side steps need to home themselves and its seems to look like it goes haywire, but it is normal as well as rolling the drivers and passengers windows up and down. You learn this through ownership. Once I returned home I gave it another two weeks and nothing happened. I decided to remove the Pulsar LT and send it in to Holley before the warranty runs out and have them check it out. I called their tech support line and explained to them what happened and I was told that I was the third person that this tech support guy heard about with the same issues as other owners of the Pulsar LT. They gave me an RMA number, warranty is only good for 1 year, three weeks later, I received my Pulsar back and they stated, through their analyzing they could not find nothing wrong and they programmed the box with the latest update and that was it. However, I haven't installed it back to into the vehicle. It has been over three months, no faults, no check engine lights, I drove over 3 hundred miles and back in the fourth month after this, no faults no check engine lights.  So your guess is good as mine. As far as programming, I did have the USB OBDII harness to update it and it is periodically checked, if programming comes into mind,  and no you can not do anything with the programming because it is all automatic with the software, you plug it in and the software or Update Agent does the rest.
Edited by AsianCajun
I have had the exact same issue with my Pulsar LT and Sierra 1500 AT4 6.2L.  It will happen anywhere from 1-2 times a month.  When I contacted Range, a couple months ago, they said they had not heard of that issue.  I bought mine over a year ago so I'm out of luck with the warranty.  For the longest time, I didn't connect all the service warnings with the Pulsar LT until I started reading about others having the same issues.  What I usually do is just disconnect the negative terminal of the battery, wait a minute, and then reconnect it.  That clears up the issues.  Do you think that an update to the Pulsar LT will correct the issues?  I really like my Pulsar LT and all the flexibility it offers, and I don't want to get rid of it, but I'm tired of having to disconnect the battery every couple of weeks.
I had this issue a couple of times with my 5.3 since I installed the Pulsar.  Last time was about 6 weeks ago when driving home from the vet with my puppy on a 98 degree day.  Finally got it home and remembered the fuse block TSB.  All 4 bolts were over a turn out from the proper torque setting.  Torqued them down properly, and haven't had it happen again.  While sitting in a parking lot, I did try to just disconnect the Pulsar, and in the process popped off one of the red dial retainers.  Anyone know if those can be purchased separately?  I'm going to have to remove it before my inspection in December, so I may as well replace it when I do it.
Did anyone notice the 10 speed transmission acting weird (hard shifts, seems like it doesn’t know what gear to be in, clunks) when they installed the pulsar LT on their 2020 5.3?
On 8/31/2022 at 4:19 PM, Johnny Johnston said:
Over 20k miles on my Pulsar, took it off a few times for oil changes etc.
Never any issues yet of any type, works as it should for me and I am very happy with it.
Cheers
Not as many miles but a couple months on a ‘19 5.3 8spd.
zero issues. Love it!
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
    • Stabilitrack was a stability control, traction control system, that functioned independently from the transfer case.   Z-71 has nothing to do with the transfer case or differential.   If it does have an AWD system, my memory recalls this being specific to the Denali trim, converting won't be as simple as swapping out mechanical parts like differentials and transfer cases. It will require reprogramming at a minimum. Long story short, not likely worth it.   Pulling a fuse, may disable the AWD system, it might also prevent any other transfer case functions.   However, the AWD case was generally based on the same transfer case you refer to in the 2006 Suburban. If it still has a 4-High and 4-Low where the transfer case locks and splits power 50-50 front to rear, what are you gaining by changing anything? A true-rear wheel drive only, what good will that serve? Not enough to go through the trouble of changing out all the parts.    Generally, all the factory systems will handle a 33" tire and re-gearing. Probably a 35" tire too, if you aren't driving like a caveman. If 35" tires are in the plan...   If you do plan on driving like a caveman or are fully committed to 35" tires, an entire re-think of the build is probably in order. Starting with square one, an IFS front end isn't going to be the best starting point for 35's and caveman driving.
    • 1/2 qt over full ain`t gonna hurt $h!t. Most times, a whole qt won`t either. Most have windage trays now. As long as the crank isn`t slapping itself in the oil, it`s not the end of the world.   We used to overfill 1 qt at the track, at race time. Better to have it over full than having the pan sucked dry at 6500 rpm`s.
