8 minutes ago, MORSNO said:
Just my opinion from years of GM truck ownership, don't do it.  The factory exhaust will literally last forever, aftermarket exhaust systems like Flowmaster will rust out prematurely and your stuck replacing them over and over and there is no performance gained.
Makes sense. I had a 2007 Classic with duals and they did rust.
The main reasons I want to do it is to let it breathe easier and better mpg
But, this evidently won't happen?
Funny you say that. I also have a 1999 GMC Sierra SLT (new body style) and when I bought it, glass packs and such were all the rage. Hell, even my 1988 Silverado was straight piped and a gutted converter. Sounded great. People asked when was I going to replace the exhaust and I said I'll wait until the original rusts out and then do it. Well, 22 years later, it still looks good! LOL!
21 hours ago, MacLaren said:
Runnin boards will be here tomorrow.
I then want to put some Flowmaster dual exhaust on her. Has anyone else put a Flowmaster dual exhaust on theirs yet?
I just put a flowmaster in place of the factory muffler and a stainless  tip.  I love it.  Aftermarket will eventually rust at the welds, but it takes years.  To me, it's worth the sound.  I am 51 and have had a muffler or some sort of exhaust on every single vehicle I have owned.
Edited by Limelight
I got the chevy (ie Borla) performance exhaust. Used points and they had a 25% discount offer in January. The sound is just right - no drone but a great deep tone under acceleration. And, having had Borla on past vehicles, I’m pleased with the quality.
Dual exhaust isn't going to let it breath any better unless it's true duals where you have 4 cylinder going into their own pipe out the back. If the dual exhaust is happening after the factory y-pipe with 2 or 3 cats plus the merge, the dual exhaust is purely for sound and looks.
You made a good choice.  7,000lbs is a good breaking point for a HD truck and very much so past 28' on travel trailers.
A 1500 is absolutely fine, especially if you do infrequent short trips.  I started towing with a really old 1500 and once we realized we tow several times a year for really long distances, the HD was a no brainer.
I dont think you will notice much power oomph, and the HD gas still has a 6 speed transmission which may feel like a downgrade if you came from an 8 in the 1500.   While the efficiency is a downgrade, the 6 speed is an upgrade in durability.
Go ahead and grease all the zerks now if you haven't done so yet!
Thanx man. I appreciate that.
Yeah, I think it's gonna be a huge difference in towing.
Happy with my black, but the blue was my first choice, just wasn't any around last spring when I was shopping. Did that safety package for the steering controls keep you in the 7" display screen? I don't need a bigger screen but would like the controls if that safety package is compatible with the 2020 7" monitors. Now that winter is out of the way, I'm going to pick up where I left of on a couple mods.
I think it did keep me in the 7" screen, but it's hardly any different from 8" screen on my 2019 5.3
But, the driver info center is just like my 2019 5.3 and, that's nice.
  • 4 months later...
On 2/26/2021 at 5:17 PM, ShotgunZ71 said:
You'll be fine with the 6.6 gas 2500HD. The stability, braking, etc is what you'll notice the most. For reference, I had a 2500HD with that engine and pulled our 42' 15k 5th wheel very well. The engine revved when it needed to, but nothing unexpected. It never got me in a situation where I felt it couldn't keep up. That's the main thing.
What the above poster is well said and exactly what I would say about mine.  I had a 19' 1500 AT4 with a 6.2 and a 19' Denali with a Duramax and I like this truck better that both of the others.................No, it isn't a Diesel, but it does a good job for me both pulling my hunting toys and my camper..................Good luck,  RR
I got a 21 gmc sierra 3500hd regular cab 8ft bed srw 4x4 sle, the difference between 2500 & 3500 is the 3500hd comes with a more heavy duty rear end 12inch vs 11inch on 2500hd and 2 overload springs on 3500hd the rear end on a 2500hd  is only rated for 6600lbs while the 3500hd srw is rated for 7250lbs which gives higher payload capability slightly higher gooseneck capacity,  while conventional towing is the same as 2500hd gas standard tire on 2500hd is 17inch vs 3500hd is 18inch otherwise both are identical
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
