I have the Undercover Ultraflex trifold and absolutely love it. Would highly recommend it if you decide on a hard trifold since to access the full bed the cover is held up by two rods vs Bakflip leans against your window/cab.
Take a look at Lomax https://www.agricover.com/lomax/
Got it a couple months ago and have a positive experience.
  • It does not leak (a little dribble by tailgate but a bed seal would fix)
  • Auto drop tailgate functions fine
  • Install and operation is simple
  • Super easy to remove when need whole bed (just pull a strap and lift off, rails stay in place)
  • Just as easy to put back on
  • Can drive in 2/3 open configuration
  • Looks cool (got the diamond plate which works great with my White/Chrome LT
I would highly recommend the Lomax also. I have the black one instead of the diamond plate. It is very clean looking, weather tight, and works well with the power drop and lift tailgate.
BakFlip MX4 here.......love it!
Allows full bed usage by flipping it all the way forward and can support my weight.,...good for snow loads in the Winter.
Not a fan of the floppy tonneau style covers at all, spend the bucks and get a hard cover.
I ended up getting the $200 Amazon Gator roll up cover for my Sierra. I liked the lower profile fit. Keeps water out. I’m happy with it. Let’s see if it holds up over the years , oh no issues either with the automatic tailgate release.
Edited by 21GMC
Added
I am in the market for a Soft roll up cover and narrowed it down to Access Lorado (~$500), Truxedo Lo Pro (~$400) and this Gator SRX (Amazons is ETX) for like $220.. Can you give us a quick update of how yours is performing..
Thanks,
Dan
Thanks,
Dan
Not sure if the Truxedo Lo Pro will work any better, but I got the Truxedo TruXport and was very disappointed that the automatic tailgate did not work.  If you go with Truxedo, or any brand, get a commitment that your tailgate will work if you have an automatic tailgate.  It’s not a big deal, but it drives me crazy when something doesn’t work properly.  I also have the multi pro tailgate so it may act different on the standard tailgate.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 1,921 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
