I moved the shovel to the to the other M.A.P.S. bed panel and mounted a WaterPort to the passenger side panel.  Much to my surprise, when mounted it sits darn near perfectly to the panel and fender.  It pressurized nicely and has held up well so I'm pleased with it thus far.
The truck is getting very close to how I imagined it, I just have to finish the winch.
  • 6 months later...
Went to Colorado a couple weeks ago and made some big upgrades before leaving. I needed to get my tent up higher so I could close my tonneau cover. I used 1.5x.120" DOM tubing for the new bed rails. They are mounted to the stake pockets, not the bed side so they can be removed with 4 bolts.
After a lot of arguing with myself I used the stock running board brackets and 1.75x.120" DOM for a set of rock sliders. This is not a rock crawler but I did bang them on Black Bear Pass and they survived with no body damage.
  • Like 4
On 10/10/2022 at 1:10 PM, Robert Peters said:
Not a bad view at 12,000ft.
Now that's a view worth having a truck!!
On 8/25/2021 at 7:31 PM, dudleyfj40 said:
I found a "water proof" outlet to for the AC unit.
Made a small panel that I can turn on lights from the back or front with my up-fitter switches.
Then fabbed up a mount for the AC unit.
what AC unit is that???
Pretty sure any 5000BTU window AC unit will work.
  • 2 years later...
Not a cheap option by any means, but I love my FabFours Matrix bumper with prerunner. It affords me 2x 3” cubes on each side (2pair) plus a 30” light bar but is also able to mount a winch. I mounted an open road 13500 winch. Any winch you mount has to relocate the control box if you have a 30” light bar installed but it’s really not that big a deal. I actually prefer having the control box in the engine bay, it’s much higher and I’ve had my whole bumper underwater/mud several times. The control box is the weak point so far as “ipx67 ipx68” is concerned. My box in the engine bay never gets wet, I’d have to screw up big to accomplish that with a 3.5” lift and 35” tires on it.
For sale: Snugtop Rebel with windoors, carpeted, auto locks, etc for sale. Standard size bed. Located in mission Viejo, CA. See picture above/below Asking $1900
Edited by Delson0
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
